Thread: p0304 error
    Oct 2010
    manchester
    Vehicle : vectra sri
    Engine : 1.8 vvti
    Mileage : 77000
    Default p0304 error
    Had this code come up yesterday with the engine management light had the code read and cleared by a friend who said its a misfire on injector 4 and to see if it comes back up as could just have been in the memory and popped up because its cold. Now the problem is the engine management light hasnt cone back on but the car is very jumpy at low revs. Am I best replacing the spark plugs and see if this helps
    My car Is an 06 1.8 sri nav
    Regular Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    12 Post(s)
    Vehicle : Insignia
    Engine : 1.6T SIDI Petrol
    Always check them first, it may be they are due to be changed anyway. If this does not sort it you will be looking at replacing the coilpack next.
    Vehicle : .
    Trim : .
    Engine : .
    Year : .
    Yeah, check ya plugs, check for air leaks, give the injectors a flush threw with some injector cleaner and then if any if the above doesn't sort it, change the coil pack.
    Sent from my iPhone 5 using Forum Runner
    Regular Member vmb2722's Avatar
    May 2012
    Blackpool/St Mary's Bay
    19 Post(s)
    Trim : Exclusiv
    Engine : 1.9 CDTi 150
    You may have a dodgy HT lead, sometimes a small break of the innards or a tiny tear in the coating can cause a misfire and lumpy running.
    Not an expensive fix yet not one many tend to consider!
    Dec 2011
    Seaham
    No HT leads, it is a coil pack!!
    Chek to se if there are any more codes that have been recorded.
    May 2012
    19 Post(s)
    Trim : Exclusiv
    Oh yeah, sorry, brain fart, was thinking of the wifes car!
    Dec 2011
    Seaham
    I have done the same thing many a time, it is worse when you start talking about points, condensers and ballast resistors.....
  1. P0420, p0301, p0304
    By GCusdin in forum Engine & Drivetrain
    Last Post: 24th February 2013, 14:26
  2. HID Kit ? Error ?
    By BigBadDamo in forum Electrical & ICE (including SatNav)
    Last Post: 28th August 2012, 09:10
  3. P0304 help
    By pogvec in forum Engine & Drivetrain
    Last Post: 16th February 2012, 14:36
  4. P0301 & P0304 misfire
    By tridley in forum Engine & Drivetrain
    Last Post: 27th September 2010, 00:06
vectra p0304
