Results 1 to 8 of 8
Thread: CD70 Aerial
    Feb 2010
    Edinburgh
    Engine : 1.9 CDTI 150
    Default CD70 Aerial
    Hi,
    I have now decided to swap my CDC40 GID and DAB for the CD70 and CID that I have, I have now purchased an satnav small black square aerial from eBay, the problem I have is I can't find anywhere to mount it as I have a centre speaker fitted. I have the vaux sat nav aerial, but that looks quite a big job to fit.
    can anyone please help ?
    It has taken me three weeks to come to this decision, weighing up DAB over Sat Nav. I just hope I am making the right decision.
    Mar 2009
    morecambe
    54 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    mount it behing the air vents on the metal bracket
    Regular Member kenp's Avatar
    Feb 2008
    Kr. Hyllinge, Denmark
    Vehicle : Insignia
    Trim : Dynamic
    Engine : 1.6 turbo
    Year : 2019
    Mileage : 44000
    Ive put mine at the center at the windscreen. And hidden the wire along the windscreen, until i could get it into the dash. Been there for like 3 years now.
    Feb 2010
    Edinburgh
    Is this behind the centre vents ?, and will it get signal from there ?
    Feb 2010
    Edinburgh
    Bump
    Regular Member Handyandy-UK's Avatar
    Mar 2009
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Your location should give the antenna as clear a 'view' straight up and skywards as you can give it, with as few dense obstructions as possible and ideally without too much electrical beside it.
    You may find with the vents removed you can adhere the antenna to the underside of the dashboard's upper surface - the plastic shouldn't obscure the signal to any huge degree. All kind depends on length of available cable as to where you can locate it.
    Feb 2010
    Edinburgh
    Thanx, at the moment to test it i have wedged it, in between the dash and the black vent tube, and it worked, just need to secure it properly soon. i am just hoping i made the right decision getting rid of the CD40+DAB for the CD70 Sat Nav combi.
    Regular Member wardy23's Avatar
    Nov 2011
    North Yorkshire
    Vehicle : vectra
    Trim : sri
    Engine : 2.2
    Mileage : 64000
    running the proper wiring takes about 20 mins i did this in my vec as its only had the cd30 in it when i got it
  1. cd70 gps aerial
    By mrk in forum Vectra C / Signum Car Chat
    Last Post: 2nd March 2012, 17:44
  2. Cd70 external gps aerial
    By simonwrx in forum Electrical & ICE (including SatNav)
    Last Post: 30th January 2012, 22:29
  3. CD70/NCDC Aerial
    By bigmac in forum Parts for sale
    Last Post: 15th August 2009, 18:41
  4. CD70 Aerial Socket
    By 137mph in forum Electrical & ICE (including SatNav)
    Last Post: 29th November 2008, 01:23
