Thread: Z19DTH Drivesafts
    Jul 2011
    Staffs
    Default Z19DTH Drivesafts
    Hi guys, I need the O/S driveshaft as the inner boot had split which has caused the joint to wear. I've spoke to various places (GSF, ECP, J&R) who have all told me that the driveshafts for my car are the same for each side. Even on the GSF site there is only one shaft listed for the left and right hand side.
    Basically i was under the impression the O/S shaft was longer than the N/S as there is a half shaft bearing which connects it to the ge. My question is this, is it just a case of removing the old shaft from the original bearing and replacing with the new one? Or is it more complex than that?
    Thanks in advance
    Regular Member omega63's Avatar
    Jul 2010
    Droylsden, Manchester
    15 Post(s)
    Vehicle : Insignia 2.0L CDTI SRI hatchback
    Trim : Black leather
    Engine : A20 DTJ 128 HP
    Mileage : 126,000
    The o/s driveshaft goes into a bearing housing mounted to the rear of the engine i think???, i know it does on the V6 diesels, this makes both driveshafts the same. The n/s driveshaft goes directly into the g/box, ....
    wirral
    61 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Drive shaft are sane the o/a goes into bearing an meets intermediate shaft.
    Jul 2011
    Staffs
    Quote Originally Posted by omega63 View Post
    Quote Originally Posted by Critch View Post
    Thats for the speedy replies guys, so just to make it simple. The old one comes out of the housing, the new one goes in?
    Jul 2010
    15 Post(s)
    Mileage : 126,000
    Sort of yes!, you will need to prize the inner CV joint o/s off/away from the bearing housing, firstly you will need release the stub axle assembly o/s/f to be able to remove the driveshaft completely....
    Regular Member XPCobra's Avatar
    Dec 2010
    Glasgow
    Vehicle : Vauxhall Vectra Hatch
    Trim : SRI with added X-Pack
    Engine : 1.9 16v 150
    Mileage : Near 100K
    Why not just replace the inner cv joint? Should be cheaper than the complete driveshaft.
    Dec 2010
    Cambridge
    Vehicle : VectraC CDTI 150
    Year : 07
    Mileage : 175000
    http://www.jandrcvjoints.co.uk/
    Try here,they have all.Bought one from them a few mounts ago,was about £60 delivered. 2 years unlimited mil. wor.
    http://www.jandrcvjoints.co.uk/vauxh...-2004-onwards/
    here u go mate
    Dec 2010
    Glasgow
    Mileage : Near 100K
    I have also dealt with J&R and recommend them highly.
    Jul 2011
    Staffs
    That's where i have got them from only down the road from me!
  1. Z19dth DMF
    By neill in forum Vectra C / Signum Car Chat
    Last Post: 4th September 2012, 15:30
  2. Oil for z19dth
    By neill in forum Engine & Drivetrain
    Last Post: 18th July 2011, 18:45
  3. Oil for z19dth
    By neill in forum General Chat
    Last Post: 18th July 2011, 01:00
  4. z19dth
    Last Post: 22nd April 2011, 08:38
  5. Z19DTH - Which Oil?
    By treadstone in forum Vectra C / Signum Car Chat
    Last Post: 3rd March 2011, 17:22
vectra c intermedia shaft bearing
