Results 1 to 9 of 9
Thread: P0380 - Glow Device General Error
    Regular Member Billy Mc's Avatar
    Jun 2012
    Bolton
    Vehicle : Vec C
    Trim : SRI
    Engine : 1.9 cdti 16v
    Mileage : loads
    Default P0380 - Glow Device General Error
    got fault code P0380 - Glow Device General Error.
    i want test the glow plugs off the car
    engine is 1.9cdti 16v z19dth
    1 } would a deep socket reach
    2 } is it a 9mm
    3 } is there an easier way to test them in place
    i know it could be the relay but wanted to rule this out first.
    thanks in advance.
    Jun 2012
    Bolton
    Vehicle : Vec C
    Trim : SRI
    Mileage : loads
    wirral
    61 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Quickest way to test glow plugs I use is volt meter and ohm meter.
    pull plug covers an out black lead to engine block an red on top of glow plug each plug should read under 1 ohm
    A dud will either show really high ohms or open
    then place red volt meter lead in plug and cycle ignition should see 12v showing that the circuit operates as it should.
    I use a deep quarter drive socket and ratchet. And never had any trouble.
    but need to be aware that their is possibility of glow plug breaking but best tip is get engine nice and warm and should be fine hope that's of some help
    wirral
    61 Post(s)
    Trim : Basic
    Engine : 1.9
    Just so you know the halfords socket would probably only be penny's difference to go in store an pick one up.
    it would also save having to wait on postage
    Jun 2012
    Bolton
    Vehicle : Vec C
    Trim : SRI
    Mileage : loads
    cheers critch thanks for the info
    read about snapping in head horror stories
    wirral
    61 Post(s)
    Trim : Basic
    Engine : 1.9
    I've only seen it done once. An it was probably more be side lad was rushing more than anything else I think.
    Mad day getting engine hot will help.
    using quarter drive helps too as cant transmit much force through a tiny ratchet.
    if in doubt just get some penetrating fluid on it an let it soak
    Regular Member Teapot's Avatar
    Mar 2010
    woodbridge, suffolk
    278 Post(s)
    Trim : Design+
    Engine : 1.9 CDTI 150
    Mileage : 101000
    Yep, you just need to be very careful;
    Apply plusgas and soak, unscrew plug until it becomes tight, apply more plusgas, screw back in, unscrew again, and on and on.
    Each time you unscrew it will come a little further out until eventually it will be free. Sometimes carbon buildup around the tip will cause them to get stuck on removal, even though the entire thread is free. If this happens you just need to keep pulling squarely upwards, tap back in, pull up squarely again. Dont try to lever it because it will just snap instead. Patience and persistance is the key to this job...
    Jun 2012
    Bolton
    Vehicle : Vec C
    Trim : SRI
    Mileage : loads
    thanks guys for your time
    Jun 2012
    Bolton
    Vehicle : Vec C
    Trim : SRI
    Mileage : loads
    Multimeter 9 mm deep socket lubricant and patience
    Job done thanks again guys
  1. glow device general error
    By SlowCoach in forum Engine & Drivetrain
    Last Post: 14th January 2013, 22:59
  2. Had Windscreen changed now have "general glow plug error"
    By merikiito in forum Engine & Drivetrain
    Last Post: 13th May 2012, 07:52
  3. FAULT CODE HELP: p0380-08 glow device general error
    Last Post: 19th November 2011, 17:28
  4. P0380 - Glow Device Circuit Low Voltage
    By benwalters82 in forum Engine & Drivetrain
    Last Post: 5th March 2011, 01:13
  5. Glow plug general error p0380-08
    By keith_johnson1967 in forum Engine & Drivetrain
    Last Post: 27th June 2010, 19:16
