Thread: Cd30mp3 shows 'displaysafe'
    Regular Member stfc87's Avatar
    Feb 2013
    Shropshire
    Vehicle : Vauxhall Vectra
    Trim : Sri
    Engine : 3.0 v6
    Mileage : 94
    Default Cd30mp3 shows 'displaysafe'
    Hi, I have a cd30mp3 to fit into my vectra 05 plate. Now when i install it, it reads 'DisplaySafe' I have read that it needs deleting off the old cars ECU. But can no longer do this. Is there a way round this? It works still, but would like to see the display. Thanks.
    Regular Member ThatAudioBloke's Avatar
    Feb 2013
    Newcastle, UK
    20 Post(s)
    Engine : CDTI 150
    Mileage : 103000
    Have you taken out a CD30 or some other headunit originally? If so, put it back in and have someone with Tech2 or Opcom divorce them (you'll need your car's security code for this). Then put the CD30 MP3 in, and have the same person marry the CD30 MP3 and your existing display. You'll need the security code for the new radio to do this (should have been supplied with the radio).
    The other way is to get the paired display for the CD30 MP3 and just fit that, and the radio together.
    Feb 2013
    Shropshire
    Trim : Sri
    Engine : 3.0 v6
    Mileage : 94
    yes sorry i have replaced the cd30 with cd30mp3. All i have is tje unit but no code. it was bought from a scrapyard, car has since been crushed.
    Feb 2013
    Newcastle, UK
    20 Post(s)
    Engine : CDTI 150
    Mileage : 103000
    You might be stuck then, I don't think even Tech2 allows changing a stored security code.
    Might be worth phoning around some of the decoding companies to see if they can help? You really need the security code for the (now crushed) car, which will allow you to remarry your current display with the new radio, getting rid of the "Display Safe" message. It may be possible to have this read from the EEPROM on the CD30MP3, or possibly to see if someone can re-code your CD30 MP3's security code so that it is the same as the one for your car (if you know it). I really don't know if that will work though. Sorry
    crook
    Go on diagnostics.org he will decode display
    Feb 2013
    Shropshire
    Trim : Sri
    Engine : 3.0 v6
    Mileage : 94
    Quote Originally Posted by BoostPuppy View Post
    You might be stuck then, I don't think even Tech2 allows changing a stored security code.Might be worth phoning around some of the decoding companies to see if they can help? You really need the security code for the (now crushed) car, which will allow you to remarry your current display with the new radio, getting rid of the "Display Safe" message. It may be possible to have this read from the EEPROM on the CD30MP3, or possibly to see if someone can re-code your CD30 MP3's security code so that it is the same as the one for your car (if you know it). I really don't know if that will work though. Sorry
    Thanks for the reply, I think you may be right. I have done some research on google and its looking like its a lost cause. It probably is possible somehow but its going to involve a lot of hassle and money Luckily I can return it and get my money back. My own fault for trying to be clever lol. Thanks again.
    Feb 2013
    Shropshire
    Trim : Sri
    Engine : 3.0 v6
    Mileage : 94
    jodie, thanks that site looks like the solution
    Regular Member rozzer2006's Avatar
    Jun 2009
    Glasgow
    Vehicle : vectra
    Trim : VXR
    Engine : 2.8 v6 Turbo
    Mileage : 50k
    Quote Originally Posted by stfc87 View Post
    if u have the car reg or the chassis number from the unit it should be saved on it, give plasma a pm he may be able to help you.
  1. cd30mp3
    By wardy23 in forum Electrical & ICE (including SatNav)
    Last Post: 1st August 2012, 13:22
  2. CD30MP3 with CID ?
    By opel_estate in forum Electrical & ICE (including SatNav)
    Last Post: 20th February 2012, 19:52
  3. cd30 to cd30mp3
    By slugo in forum Electrical & ICE (including SatNav)
    Last Post: 7th October 2010, 13:09
  4. cd30mp3 or kenwood ?
    By studmuffin in forum Electrical & ICE (including SatNav)
    Last Post: 18th January 2009, 15:41
  5. cd30mp3 or kenwood ?
    By studmuffin in forum Vectra C / Signum Car Chat
    Last Post: 14th January 2009, 23:04
