Results 1 to 10 of 16
Thread: Vectra 1.9cdti 150 2004 cutting out!!!
    Mar 2013
    Bristol
    Vehicle : 1.9 cdti
    Trim : Energy
    Engine : 1…9
    Default Vectra 1.9cdti 150 2004 cutting out!!!
    Please please help!!!
    I have Vectra 1.9 cdti 150 2004 and its beginning drive me insane.
    Started with lumpy tick over and lack of power. I started by putting forte diesel cleaner in which seemed to help at the beginning ( 2weeks ok ish). I then discovered a chuffing injector that was fixed,that seemed to resolve the power issues. After 2 weeks it has now stared to cut out when slowing down at junctions or changing down a gear..no warning just cuts. It starts pretty much straight away after. Another thing I have noticed is that I seem to get cutting out problems after fuelling the the ****** thing if I allow the fuel gauge to give me the low fuel light warning. I changed the fuel filter yesterday, and still the thing is cutting out on me. Seems to be getting more frequent (3 times today on a 20 mile trip).
    I don't get any warning lights on a dash at anytime.
    Anyone got any idea what I should be looking for as regards these issues? It's driving me mad and I have no confidence in the car now.
    Mar 2013
    Bristol
    Vehicle : 1.9 cdti
    Trim : Energy
    Engine : 1…9
    Oh I should say that the lack of power seems to be creeping back as well.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    You're car is a 2004 so I'm going to say throttle body problem. The solder joints crack and cause the throttle body to think that you have switched the ignition off. This shuts the plate over stalling the engine.
    Here is a how 2 on the issue: http://www.vectra-c.com/forum/showth...45#post1338145
    If it's not this then I would say the injector wiring is a problem if your plugs are yellow and not blue.
    Mar 2013
    Bristol
    Vehicle : 1.9 cdti
    Trim : Energy
    Engine : 1…9
    Thanks I will look into that. My plugs are blue not yellow.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by Freestate View Post
    My old one was doing the same - 54 plate - and the throttle bodty was the problem. It used to do it whenever it wanted.
    Mar 2013
    Bristol
    Vehicle : 1.9 cdti
    Trim : Energy
    Engine : 1…9
    Would that explain the lack of power issues?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Possibly the plate is closing slightly reducing the air flow into the engine. The diesels don't have a throttle plate but they have a shut off plate - hence the reason the cracked solder joints cause it to close. I think mine used to have the power issue to - it would develope some weird flat spots then be ok or sometimes cut out just after. Either way m8 I'd get to the bottom of that cutting out thing first as that is very dangerous.
    Mar 2013
    Bristol
    Vehicle : 1.9 cdti
    Trim : Energy
    Engine : 1…9
    Tell me about,it cut out at 50mph one time with cars all around. Must admit it was a wee bit unnerving. :-/.
    Thanks for all your help,
    will look into it tomorrow.
    Cheers. :-)
    Dec 2010
    Cambridge
    Vehicle : VectraC CDTI 150
    Year : 07
    Mileage : 175000
    Did you tryed to clean the fuell pump in the tank?
    Mar 2013
    Bristol
    Vehicle : 1.9 cdti
    Trim : Energy
    Engine : 1…9
    No I haven't done that yet.
  1. 1.9 cdti 150 2004 Cutting out lumpy
    By Freestate in forum Vectra C / Signum Car Chat
    Last Post: 13th March 2013, 19:53
  2. vectra 2l 2004 cutting out
    By larkin in forum Engine & Drivetrain
    Last Post: 13th February 2011, 21:36
  3. Where is my oil filter on my Vectra 2004 1.9cdti?
    By scoobsnack in forum Vectra C / Signum Car Chat
    Last Post: 5th August 2009, 16:37
  4. U480 Code Reader & Vectra 1.9cdti Energy (150) 2004/5
    By markluk in forum Engine & Drivetrain
    Last Post: 27th February 2009, 08:55
  5. Cambelt Change On 2004 Vectra 1.9cdti Sri 150
    By PAULMAC77 in forum Vectra C / Signum Car Chat
    Last Post: 25th June 2008, 11:24
