Thread: Compression Test
    Aug 2010
    London
    Default Compression Test
    HI,
    Can anyone help. I have a 2003 vectra c 1.8 16v (93000 on the clock)
    For the last 3 months the car has been literally drinking oil. I have not got an oil leak anywhere, so it must be internal. The car is running perfect apart from the odd occasional slightly longer to start at random times.
    I have changed the oil recently also and still the light keeps coming on. Dipstick is showing no oil also.
    Compression test shows:-
    1:-230 psi\16 bar dry
    2:-230 psi\16 bar dry
    3:- 221 psi\15 bar dry
    4:- 230 psi\ 16 bar dry
    All this was done on a cold engine. Coil pack removed and the throttle valve opened same amount on all 4 cylinders. 6 cycles per cylinder.
    Can anyone help??
    May 2012
    county durham
    Engine : 1.9 cdti 150
    Mileage : 145k
    compression seems healthy enough , but then again the oil control rings can be knackered & still have compression but burn lots of oil .
    what oil are you using ? how many miles until it uses its oil & how much do you need to put in it ?? any smoke out the exhaust when driving ?
    wirral
    61 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    What oil you using
    maybe worth trying 10w40 if your on 5w30
    Aug 2010
    London
    Thanks for replays. I would have to top up 2 lt every 2 weeks however I topped up with 1lt once and the next day it was out again. I put in 5 -30 magnates but I am now topping up and using 0-40 fully sin of castrals more expensive oil which has not helped. No smoke, only the usual when car cold but I do mostly motorway driving.
    i did see some carbon build up through the spark plug hole.
    There is definitely a problem with my oil as I'm using to much, just don't know we're. I thought the compression results were to high in respect for that being a dry test?
    wirral
    61 Post(s)
    Trim : Basic
    Engine : 1.9
    Try 10w30 fully synth an see how goes a heavier oil may be enough
  1. No compression cylinder no4
    By r9 nml in forum Engine & Drivetrain
    Last Post: 23rd November 2012, 19:43
  2. help needed...how do you compression test a z22se engine
    By Miketwinny in forum Engine & Drivetrain
    Last Post: 4th September 2011, 00:11
  3. Compression test results on Z22YH......
    By Nik in forum Engine & Drivetrain
    Last Post: 3rd August 2011, 14:09
  4. compression test 2.0 dti
    By dan9895 in forum Engine & Drivetrain
    Last Post: 23rd September 2008, 13:53
