Thread: Brake pads and discs changed
    Preston Area
    confused Brake pads and discs changed
    Just changed the front pads and discs, but the front pad indicator is still showing up on the dash.. any ideas? ( the sensor wire is attached! )
    Full Member andy.l's Avatar
    Wirral / ellesmere port
    8 Post(s)
    Vehicle : insignia tourer
    Trim : elite
    Engine : 2.0 cdti 160
    Year : 2011
    HI M8
    did the sensor indicator light up before you replaced the pads as
    if so then the sensor wires must be replaced as i dont think the
    sensors can be reused,they have to be new ones but if not then
    the light shud go out once u have braked a few times and settles
    cheers
    2011 insignia elite tourer 2.0 cdti 160 manual,silver
    Preston Area
    Yeah it did before i changed them! - oddly it lit up when i wasnt braking! but the pads were very low so I changed them anyway. The sensor wire ( only on one side ) can be clipped off and put back on.. the stealer said they didnt have to be replaced!
    yep, as andy says, it it's ever been used ( ie the pads wore down that far) then it's got to be a new one for the light to sort itself out..
    Preston Area
    reet.. if thats the case.. are they easy to change, can see where they clip into the pad, but not sure on the other end - is it normal to only have one sensor as well?
    yep, only ever one sensor fitted now, just follow the wire up and you'll find the plug.. it's a dead easy change, hardest bit will be getting the wheels off again.
    Regular Member Robward27's Avatar
    Witham
    My light came up last week got front pads changed lights now out.
  1. Changed Front Brake Pads
    Last Post: 21st January 2012, 18:21
  2. should dealer have changed my rear discs/pads
    By mitch in forum Vectra C / Signum Car Chat
    Last Post: 9th May 2010, 18:28
  3. What brake pads for 2.8 V6 Signum??? 314mm brake discs
    By luke4487 in forum Suspension, Wheels & Brakes
    Last Post: 25th February 2010, 23:21
  4. Rear Brake Pads - Changed design or just the wrong ones?
    By Angelchops in forum Suspension, Wheels & Brakes
    Last Post: 25th September 2009, 09:38
  5. Brake discs and pads
    By bish in forum Vectra C / Signum Car Chat
    Last Post: 9th August 2008, 19:57
