Results 1 to 10 of 17
Thread: Vectra C 1.9 cdti starting issues plz help...............
    Nov 2010
    Bridgwater
    Vehicle : Vectra 1.9 CDTI 120
    Mileage : 157,000
    confused Vectra C 1.9 cdti starting issues plz help...............
    Hi to all, so had real problems starting the car to the point where I'd kill the battery so now we've managed to figure out its the coolant temperature sensor so have disconnected it until I can get a new one and she starts loads better but now the cat light has come on when driving and my window wipers aren't working?? Weird I kno anyone know why that would be? Also because of disconnecting the sensor the fan is on constantly! If it wasn't needed for my job I wud leave it to sit till shops open tues :-/
    any feedback would be greatly appreciated
    thanks
    Dec 2012
    Midlands
    Mine is slow to start when cold but much better when the coolant sensor is disconnected. When replaced with a new part it made no difference. The car does a number of things differently when the sensor is unplugged. Doesn't necessarily mean the sensor is faulty if it starts better without it.
    Let us know how you get on.
    Dec 2012
    Midlands
    You could unplug, start, then plug it in before you leave?
    Nov 2010
    Bridgwater
    Mileage : 157,000
    Put new sensor on today and she starts loads better still not perfect but way better than before
    Dec 2012
    Midlands
    That's good news then, I suspect my problem is the starter motor. Sounds like its spinning quick enough but they are known to go 'lazy' and require quite a few turns before firing up. Will get round to it when I can.
    Nov 2010
    Bridgwater
    Mileage : 157,000
    she was starting lovely yesterday but now today shes being a b***h again! Do u think it's worth changing the heater plugs? Onli changed about 2 years ago?? Thanks
    May 2011
    Ashby-de-la-Zouch
    Trim : sri nav/Elite
    Engine : CDTI 150
    Year : 56
    Mileage : 130ish
    i tried new glow plugs, removed tb plate and still took ages until i replaced the crank and cam shaft sensor it starts straight away now.
    Nov 2010
    Bridgwater
    Mileage : 157,000
    Oh god! Might have to sell her had sooooo much go wrong shame tho
    Jan 2012
    Gloucestershire
    You've not mentioned whether or not you have trouble starting when the engine is hot or cold.
    If you're still getting trouble with starting with a new temp sensor then you could be looking at glow plugs, starter motor or crankshaft sensor (+ others?).
    So, for starters, when do you have starting trouble - cold/hot start?
    Also, do you have any spanner/emissions lights still?
    Nov 2010
    Bridgwater
    Mileage : 157,000
    Quote Originally Posted by DieselWig View Post
    Hiya she is especially difficult when it's cold a bit better when it's warm but not majorly, am changing the heater plugs today (which look like hell to get at) and see if that improves! There's no warning lights, spanner or anything onli thing that's changed is window wipers have stopped working and cruise control has started working?!?!? Weird I know!
  1. Vectra 1.9 CDTI [150] performance issues
    By keithsimmo in forum Engine & Drivetrain
    Last Post: 22nd July 2013, 15:05
  2. Replies: 0
    Last Post: 12th November 2012, 18:47
  3. vectra vxr starting issues
    By djmvxr in forum Vectra C / Signum Car Chat
    Last Post: 13th August 2012, 19:14
  4. 1.9 cdti (120) starting issues.
    By 2wheelstu in forum Engine & Drivetrain
    Last Post: 27th March 2012, 17:07
  5. cdti 120 bhp starting issues
    By Turbomanrony in forum Engine & Drivetrain
    Last Post: 6th December 2011, 19:45
vectra c tdci 120 starts poor and cloud of smoke
Vectra lazy starter
vectrac lazy starting
signum 1.9 starting
vauxhall vectra 1.9 cdti not starting
vauxhall vectra diesel hard to start
1.9 cdti first start problem
opel signum 1.9 starter issues
1.9 cdti starting problems
1.9 cdti long crank time
vectra 1.9 engine hard to start
vectra 1.9 cdti slow starting problems
Vauxhall vectra 1.9 cdti hard to start
vauxhall vectra starting problems
vectra c 1.9 cdti hard to start
astra 1.9 cdti starting problems
cold start problems in diesel engine vauxhall vectra cdti
vectra c cold starting issues
vectra 1.9 150 cold start issue
vectra c starting problem with new starter
vauxhall vectra c diesel starting problems
vectra 1.9 cdti cold start problem
vauxhall zafira 1.9 cdti starting problems
www.vectra-c.com vauxhall vectra starter motor removal site:www.vectra-c.com
