whats the best way to add aux to my current cd30 , I know one cannot be wired directly, what options do I have
FM modulator, Parrot MKi kit or swap the headunit for an aftermarket one, pretty much.
it is possible if you have a blaupunkt CD30
the notes are written in romanian.
the translation is:
line 1 (white): cut here
line 2 (red): bridge from pin 1 to resistor
line 3 (white): cut here too
line 4 (green): Left channel
line 5 (orange): Right channel
line 6 (Blue) Ground to pin 4
rest of the lines (yellow): to activate LINE-IN you must create a bridge with a switch between the TEL MUTE pin (from the rear plug of the CD30) and the ground point (the outer shell of the CD30)
this method was tested by several users from Romania and it was a success.
I will try it also on my CD30.
