Thread: Should there be a bolt in here?
    Nov 2012
    Perthshire
    Vehicle : Vectra SRI
    Engine : 2.2 16V
    Mileage : 78000
    Default Should there be a bolt in here?
    Vectra making a noise occasionally, over bumps. Checked out noise coming from NSF, also have an oil leak.
    Removed front wheel and found this shining thread, with no bolt in it. I thought it was just the thread from the short bolt, but it does not seem to contect to anything and does not have a hole at the back.
    I am hoping someone can tell me what this is for.
    vec 1.jpg.
    Vectra 2003 SRI 2.216V manual
    G
    Regular Member simplesi's Avatar
    Aug 2009
    probably off taking photos
    Vehicle : 1.9 cdti 150
    Trim : elite
    looks like a mount of some kind , i may be wrong but oooooooofffffffffffffffffftttttttttttttt.
    looks to me that if you follow that drag mark above it you,ll find out where it belongs
    May 2012
    county durham
    Engine : 1.9 cdti 150
    Mileage : 145k
    rear gearbox mounting
    Nov 2012
    Perthshire
    Engine : 2.2 16V
    Mileage : 78000
    I can't see the other hole the bolt would go into, in the picture. Looks like it dropped 2 inches, at least.
    Would the gearbox still work ok, that much out of alignment?
    G
    May 2012
    county durham
    Mileage : 145k
    if it has dropped that far it won't be doing the driveshafts any favours .
    Nov 2012
    Perthshire
    Engine : 2.2 16V
    Mileage : 78000
    Been too busy to get car to garage, going in on Monday, any other suggestions? Car running well otherwise now.
    Nov 2010
    East Midlands
    8 Post(s)
    Trim : design
    Try jacking the part that has dropped down, gently, until the holes align and then put a replacement bolt in
  1. What's The Bolt that...
    By Meady in forum Engine & Drivetrain
    Last Post: 21st March 2011, 23:03
  2. What is this bolt/pin from?
    By Thom in forum Bodywork & Interior
    Last Post: 14th November 2010, 17:31
  3. is this the bolt?????????????
    By vxr in forum Vectra C / Signum Car Chat
    Last Post: 10th February 2010, 08:35
  4. Usain Bolt
    By bigknill in forum The 'Off Topic' room
    Last Post: 17th August 2009, 09:00
  5. Bolt size
    By nikroc in forum Vectra C / Signum Car Chat
    Last Post: 27th November 2007, 08:36
