Thread: signum front brake upgrade
    Oct 2010
    uk
    Engine : 2.0t
    Mileage : 117000
    Default signum front brake upgrade
    Hi, my current signum 2.0t 55reg one front disk was deformated and was kicking when braking. Have another signum 3.2 v6 03reg which has larger calipers and disks. I sawp them, bleeded, but seems that there is still air in system or something, after hour of bleeding it's still braking very bad, and when i keep my foot on pedal it is going down slowly. i checked bleeding valves and hose bolts, all the time topped up reservoir while bleeding. still bad. when starting engine at first pedal goes down very easy. On old signum brakes was very good. Can it be different master cylinder for 3.2 v6? my 55reg is new shape one.
    Chelmsford
    Possibly air in ABS pump... If that's the case you'll need Tech2 to open the valves while you bleed.
    You have got the calipers on the right way round haven't you? Sorry if it's a stupid question, just heard of too many people getting them swapped left to right and having problems!
    Oct 2010
    uk
    Engine : 2.0t
    Mileage : 117000
    actually these was taken already and i didn't find R or L on them as on rear ones. the only thing is just bleeding valve a bit lower wen sawping sides, or not?
    Regular Member signumboy's Avatar
    Edinburgh/outskirts
    Engine : 2.0 Ltr Turbo
    Mileage : 38000
    Bleed nipple should face upwards I believe
    South east
    Quote Originally Posted by signumboy View Post
    Not just "I believe" - the valve HAS to be at the top, otherwise air remains in the caliper even after bleeding. If the bleed valve is too low down then you've put the calipers on upside down, because they're on the wrong side of the car.
    Jan 2012
    Milton keynes
    Trim : M Sport and Design
    Mileage : 38100
    Quote Originally Posted by Rebellion View Post
    I made the same mistake when upgrading mine... they fit both way round so can be easily done, especially when you arent paying them the correct attention. LOL.
    Anyone in your area able to give you a hand?
    Oct 2010
    uk
    Engine : 2.0t
    Mileage : 117000
    Swapped them, all fine now. thanks guys
  1. For Sale: 314 front brake upgrade
    By Sebastian in forum Parts for sale
    Last Post: 3rd April 2013, 18:36
  2. For Sale: 314mm front brake upgrade
    Last Post: 19th October 2012, 09:40
  3. For Sale: 314mm front brake upgrade
    Last Post: 7th June 2012, 21:15
  4. front brake upgrade
    By andy76 in forum Vectra C / Signum Car Chat
    Last Post: 25th April 2011, 19:20
