Thread: Low pitch rumble from heater
    Nov 2012
    Denmark
    6 Post(s)
    Vehicle : Opel Vectra
    Trim : OPC
    Engine : 2,8 V6
    Mileage : 90000
    Default Low pitch rumble from heater
    Hi,
    I have ECC and noticed today, that a get a low pitch rumble whenever the fan is running AND the engine is running.
    Engine off and ignition on I just get standard fan noise.
    It's the same wether the fan is on 1 or 7, however it disappears at setting 0.
    It's about the same volume as the engine on idle (2,8 V6), initially I actually thought it was the engine so I turned the radio and fans all the way down. It's only audible inside the cabin and I think it sounds louder because it resonates with something
    I tried to record the sound with my phone, but it's too low pitch to get picked up.
    Any ideas on what's wrong and how to fix it?
    Regular Member stuart bigboy's Avatar
    May 2007
    kent
    sounds to me like there is something in the fan under the scutle panel behind the pollen filter check there isnt anything in there
    Nov 2012
    Denmark
    6 Post(s)
    Trim : OPC
    Engine : 2,8 V6
    Mileage : 90000
    in that case, wouldn't the sound be there as well with the engine off? - I'm thinking it could be the compressor
    May 2007
    kent
    it will allways be there if the heater fans is running engine on or off
    Nov 2012
    Denmark
    6 Post(s)
    Trim : OPC
    Engine : 2,8 V6
    Mileage : 90000
    I only get the sound with the engine running
    Nov 2012
    Denmark
    6 Post(s)
    Trim : OPC
    Engine : 2,8 V6
    Mileage : 90000
    Just had a thought. In the morning I'll see what happens if I disable the AC in the menu. If it stops, it must be the compressor
    Nov 2012
    Denmark
    6 Post(s)
    Trim : OPC
    Engine : 2,8 V6
    Mileage : 90000
    As I expected the noise stops if I turn AC off in the climate menu. Is that a new compressor?
    Regular Member yorkshire007's Avatar
    Mar 2013
    Huddersfield
    Trim : Elegance
    Engine : 2.0 Dti
    I changed my pollen filter and the noise from the heater roughly halved. Hopefully this will help you.
    May 2012
    county durham
    Engine : 1.9 cdti 150
    Mileage : 145k
    Quote Originally Posted by brasch View Post
    hard to say without hearing it but it might well be normal , the engine note will change slightly when the compressor is running .
    Nov 2012
    Denmark
    6 Post(s)
    Trim : OPC
    Engine : 2,8 V6
    Mileage : 90000
    well, it's only audible from inside the cabin, but not at all on the outside. Could sound like a compressor running low on cooling agent - where is the compressor located and is there any way to check if it's running low or not? If so, is it possible to fill it up again?
  1. Long winded pitch to sell a car
    By decks in forum Vectra C / Signum Car Chat
    Last Post: 6th January 2013, 20:39
  2. High pitch noise
    By shaun_richmond in forum Suspension, Wheels & Brakes
    Last Post: 13th May 2012, 19:46
  3. Interesting sales pitch??
    By mitch1965 in forum The 'Off Topic' room
    Last Post: 30th October 2009, 01:11
  4. Vectra-C Pitch @ PVS
    By parapaul in forum PVS 2008 - June 8th
    Last Post: 4th June 2008, 19:57
  5. high pitch noise
    By tjsingh in forum Suspension, Wheels & Brakes
    Last Post: 16th January 2008, 09:49
