Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: oil filter housing on 3.2 gsi
  1. #11
    Sep 2012
    expat Lancashire lad in the Midlands
    Engine : 3.2
    Seriously thinking of doing this next time I need an oil change as I find the housings seem to torque themselves up over time even if you put them on with the right torque and they are an absolute ballache to get off.
    One question - does the connector need tightening itself or is it just fixed in place by the spin-on filter?
  2. #12
    The connector is used with permanent threadlock on the engine block side and needs tightening as far as it will go into the engine block.
  3. #13
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    Nice info there :-)
  4. #14
    bexhill on sea
    hi, will this mod work on my vectra c gsi 3.2 on a 2002 plate.
    thanks.
  5. #15
    New Member Andytit's Avatar
    Feb 2022
    Kingsclere
    Vehicle : Vectra c
    Engine : 3.2 v6 petrol
    Quote Originally Posted by vectra gsi 3.2 View Post
    ignore me i is an idiot, thought it was the outside casing for the oil filter u could not shift..........
    Yes can't get cap off because the whole housing is turning
  6. #16
    Feb 2022
    Kingsclere
    Vehicle : Vectra c
    Quote Originally Posted by Drinky View Post
    You need to grip the alloy housing with some large grips to stop it turning then undo the plastic cap.
    How much has it turned already ?? as any more than a few mm will snap the locating lugs from the back into the block.
    I have modified mine with a threaded union from VX for a X25XE engine you remove the entire alloy housing then replace with the union then you can use spin on filters !!!!
    Mines been turned quite a bit I think the lugs on the back must be broken
  7. #17
    Feb 2022
    Kingsclere
    Vehicle : Vectra c
    I just tried to get that part from vx and they are saying they don't sell it separately???
  8. #18
    Regular Member Sindy's Avatar
    Dec 2015
    Yorks
    5 Post(s)
    Trim : Mohican
    Engine : Z20NET
    Don't shoot the messenger if wrong, but from 5 minutes of reading it seems the part got superceded by 90144360.
    Quick search on that shows in stock everywhere, even eBay.
    I'd double check yourself though.
  1. 3.0 d Oil filter housing
    By Faz2726 in forum Y & Z30DT Specific
    Last Post: 14th February 2013, 17:06
  2. help me please oil filter housing
    By kamazoo in forum Vectra C / Signum Car Chat
    Last Post: 28th July 2012, 22:03
  3. GSI Oil filter housing
    By sickboyjay in forum Engine & Drivetrain
    Last Post: 23rd March 2011, 15:06
  4. fuel filter housing
    By daddyjay in forum Vectra C / Signum Car Chat
    Last Post: 26th September 2010, 13:19
  5. oil filter housing
    By andymcniven in forum Engine & Drivetrain
    Last Post: 27th March 2007, 16:47
vectra 3.2 gsi oil filter
buy connector oil 90412159
vectra c oil filter housing nut
vauxhall vectra gsi 3.2 oil filter housing removal
90412159
How to remove iol filter from holden vectra v6
vectra c 3.2 oil filter housing
3.2 vectra oil filter housing change
https:www.vectra-c.comforumshowthread.php184587-oil-filter-housing-on-3-2-gsi
