Results 1 to 10 of 14
Thread: oil filter housing on 3.2 gsi
    Regular Member stuart bigboy's Avatar
    May 2007
    kent
    Default oil filter housing on 3.2 gsi
    hi there just tried to change the oil filter on my gsi when trying to undo the front nut the whole housing seems to be turning so i have stopped untill i can get some advise on it has any one else had this problem and if so whats the cure for getting it sorted
    Aug 2012
    worcester
    Vehicle : 3.2 gsi
    Trim : gsi
    Engine : 3.2 v6
    spray wih wd leave for a couple of days usually frees of the alloy
    You need to grip the alloy housing with some large grips to stop it turning then undo the plastic cap.
    How much has it turned already ?? as any more than a few mm will snap the locating lugs from the back into the block.
    I have modified mine with a threaded union from VX for a X25XE engine you remove the entire alloy housing then replace with the union then you can use spin on filters !!!!
    May 2007
    kent
    it only moved very slightly mine has the alloy cap and alloy body think i am going to have to put it in the garage cos i have tried holding the body but it wont budge second time this has happend last time had to have housing replaced
    May 2007
    kent
    tried everything i can think of still wont budge
    Regular Member vectra gsi 3.2's Avatar
    Dec 2011
    vx - outlaws...
    8 Post(s)
    Vehicle : gsi
    Trim : quality
    Engine : 3.2
    can u not borrow one of the wee tools with a small seatbelt style strap and once on its easy peasy to remove.........
    Dec 2011
    vx - outlaws...
    8 Post(s)
    Vehicle : gsi
    Trim : quality
    Engine : 3.2
    Quote Originally Posted by vectra gsi 3.2 View Post
    ignore me i is an idiot, thought it was the outside casing for the oil filter u could not shift..........
    May 2007
    kent
    i have tried that any way holding the casing and turning the end but still wont budge
    May 2007
    kent
    has any one got any other ideas this is the second time this has happened to me its becoming a pain in the but need to get the oil filter changed
    This is the how to i used
    How2 to convert your old metal element oil filter, to a new spin on type.
    Why would you want/need to do this?
    The numpties at the garage that did the last service used an impact wrench to put it on, and you break it trying to get it off.
    You can't get the top off at all and you resort to cutting it off!
    And VX want to charge you nearly £200 for a new housing!
    This is the metal housing the element filter sits in. The housing is attatched to the block via a hollow bolt inside, and should be torqued up at 45Nm. The cap should be torqued up at 15Nm.
    So you find yourself in a pickle, because some part of the housing is damaged, and being frugal you don't wish to part with a shed load of cash, what do you do?
    firstly you arm yourself with these parts.
    1x Standard spin on vauxhall oil filter OF93
    1x Connector, oil PN 90412159 (£12.15 + vat 07/2010)
    1X Bottle Permanant studlock
    Proceed to remove the damaged part, using you favourite method, cap takes a 24mm socket and the bolt inside takes either a 27mm socket or a 12mm hex drive to get the centre nut out of the base of the canister. (best have your favourite oily rag handy )
    Once removed, thoroughly clean the area, including the threads in the block.
    Apply some studlock to the threads in the block, grasp your connector firmly (doesn't matter which end) and apply some studlock to that as well
    Insert conector into block
    Now, put some oil in the filter, and some round the rubber seal and spin on your new filter, no nut on the end of these, but you've done enough of these to know when its seated properly
    Now pat youself on the back for a job well done
    Next time you do an oil change, you will be able to get your filter off no problem
  1. 3.0 d Oil filter housing
    By Faz2726 in forum Y & Z30DT Specific
    Last Post: 14th February 2013, 17:06
  2. help me please oil filter housing
    By kamazoo in forum Vectra C / Signum Car Chat
    Last Post: 28th July 2012, 22:03
  3. GSI Oil filter housing
    By sickboyjay in forum Engine & Drivetrain
    Last Post: 23rd March 2011, 15:06
  4. fuel filter housing
    By daddyjay in forum Vectra C / Signum Car Chat
    Last Post: 26th September 2010, 13:19
  5. oil filter housing
    By andymcniven in forum Engine & Drivetrain
    Last Post: 27th March 2007, 16:47
vectra 3.2 gsi oil filter
buy connector oil 90412159
vectra c oil filter housing nut
vauxhall vectra gsi 3.2 oil filter housing removal
90412159
How to remove iol filter from holden vectra v6
vectra c 3.2 oil filter housing
3.2 vectra oil filter housing change
