Thread: Anyone know what a "SAFEGUARD" warning in info display means?
    Regular Member andy d's Avatar
    Feb 2006
    Inverkip
    Question Anyone know what a "SAFEGUARD" warning in info display means?
    Switched the ignition on this morning on my 06 cdti 150 and got a warning on my info display reading "SAFEGAURD" , I haven't got a clue what it means although the car alarm did go off last night in the wind, don't know if this was linked!
    I switched it off via the left roller switch on the sreering wheel but still a bit worried about the cause
    Any suggestions most welcome
    Andy D
    Yep, check safe guard is an alarm fault ...If it was just safeguard it is probably telling you the alarm wasw activated.
    Feb 2006
    Inverkip
    Quote Originally Posted by Bainie View Post
    Cheers Bainie, I feel a load has been lifted from my shoulders already, only got the car a few days ago and still at the getting to know it stage.
    You know the way you've just traded in a crackin motor and think you're beginning to wonder why....lol
    Quote Originally Posted by andy d View Post
    Know that feeling only too well *lol*
    mansfield notts
    safeguard is the cars way of telling you that the alarm has been activated, whatever the cause. if your alarm/immobilliser light stays lit for about 10seconds without binking it indicates there is a problem with the alarm system itself, but as you suggested the alarm was triggered by the wind, when you lock the car the red light should blink fast for 10secs then blink at 15sec intervals, if so all is well
    my vectra sri was showing safeguard every time i put the key in, even when i took it out and in again. but more oddly, the rear screen heater would not work while having this problem but it seems that the electronics are are self diagnostic which sorted everything out, eventually
    Feb 2007
    North west
    You must have had really bad wind to set the alarm off, ive blasted some whoppers out myself but never enough to activate the alarm...
    Quote Originally Posted by sipop View Post
    Nope. The "check safeguard" or "safeguard check" message (depending on which year handbook you look in) is informing you that there is a system error with the anti-theft alarm system.
    That's not right. If the light blinks for the first 10 seconds, it's indicating door / bonnet / boot is open, or there is a system fault.
    The light should come on and remain on for the first ten seconds, then start flashing.
    All the above is mentioned in the car's handbook.
    Full Member Robsey's Avatar
    North East Cheshire
    14 Post(s)
    Trim : Energy
    Mileage : 131,000
    Check safeguard often means that someone has detatched the wires for the ultra sonic sensors near the rear view mirror...
    very easy if you have upgrade or reverted back the "dome" / interior light or fitted a sunglasses holder.
    Lower the plastic housing, held by 3 torx screws and check the connectors...
    try this thread...
    http://forum.vectra-c.com/showthread.php?t=29944
    Jul 2006
    Quote Originally Posted by rob 2.2dti View Post
    quality!
    Regular Member pint's Avatar
    Aug 2016
    fife
    Vehicle : vectra c
    Trim : design
    Engine : 1800
    Mileage : 92000
    I had 'Safeguard check' for a while. Checked fuses.....OK. Alarm works OK so didn't do anything about it. Sat playing in the car the other day locked myself in (As you do) and pressed the safeguard button held it in till stopped flashing and now no more Safeguard message.
  1. Another "safeguard" question!
    By lurcherman in forum Electrical & ICE (including SatNav)
    Last Post: 2nd July 2013, 20:37
  2. Screen showing "safeguard" ??
    By SlowCoach in forum Electrical & ICE (including SatNav)
    Last Post: 7th June 2012, 23:59
  3. "Check Safeguard"
    By hadiislam in forum Electrical & ICE (including SatNav)
    Last Post: 4th June 2012, 13:59
  4. "Check Safeguard" on Display
    By BigMan in forum Electrical & ICE (including SatNav)
    Last Post: 14th March 2012, 21:07
  5. "Check Safeguard" Message
    By Loz2286 in forum Troubleshooting
    Last Post: 14th February 2011, 16:47
vectra c safeguard
vauxhall vectra safeguard on display
check safeguard vectra
safeguard on vauxhall vectra
vectra safeguard
vectra c check safeguard
what does safeguard mean on a vauxhall vectra
safeguard vauxhall vectra
vectra c safeguard warning
https:www.vectra-c.comforumshowthread.php18458-Anyone-know-what-a-quot-SAFEGUARD-quot-warning-in-info-display-means
what does check safeguard mean on a vauxhall vectra
vauxhall vectra safeguard warning
vauxhall vectra check safeguard
vauxhall safeguard
vauxhall vectra safeguard message
vectra safeguard reset
vectra c safeguard message
safeguard vauxhallvectra says safeguard on dashvectra check safeguardsafeguard check vectravectra c safety alert displysafeguard on a vauxhall vectravectra safeguard warning
