Thread: Engine hesitant if driven hard, fuelling?
    Sep 2011
    Surrey
    Default Engine hesitant if driven hard, fuelling?
    Basically as title says, if I accelerate hard high up into the rev range I find the power drops and I get this hesitancy through some of the remaining gears, I can only think it's a fuelling issue so maybe a new fuel filter will cure it???? I really don't know so if someone has an idea I'm all ears, thanks.
    Regular Member stevoxsi's Avatar
    Sep 2012
    Coleraine, Norn Iron.
    Vehicle : Insignia
    Trim : Sri Vx-line
    Engine : 2.0 Cdti 160
    Year : 2011
    Have you done the airbox mod? I'm conviced it helped mine.
    Sep 2011
    Surrey
    Would you care to explain as I'm not too sure what this is, is this removing what looks like a blanking piece of plastic in the airbox it's self or something else?
    Sep 2012
    Vehicle : Insignia
    Trim : Sri Vx-line
    Year : 2011
    There's a funnel shaped bit of plastic on the bottom of the box which clips out. Seems to cause only half the filter to get used. Should be a how2 on it.
  1. Ticking 2.8 v6 auto and loss of power when driven hard
    By chunkey_monkee in forum Engine & Drivetrain
    Last Post: 13th February 2013, 23:25
  2. Struggling to start after re-fuelling
    By Bloicy 3.2 V6 GSI in forum Vectra C / Signum Troubleshooting
    Last Post: 1st August 2011, 18:50
  3. Engine is 'hesitant'
    By bighammerfan in forum Engine & Drivetrain
    Last Post: 30th September 2010, 09:34
  4. Hesitant 1.9cdti with engine light
    By DVectra55 in forum Engine & Drivetrain
    Last Post: 23rd March 2010, 11:41
  5. V6 CDTi Judder/Under-fuelling at Idle
    By ukanalyst in forum Vectra C / Signum Troubleshooting
    Last Post: 20th May 2008, 22:42
