Thread: starting issues
    Regular Member kylewareing's Avatar
    Feb 2013
    bolton
    Vehicle : 1.9 cdti 120
    Trim : mix& match
    Engine : Turbo Diesel
    Mileage : 91000
    Default starting issues
    Car is a December 2006 c with the 1.9 (120) 8v engine
    upon starting, wether hot or cold the engine seems to either
    *crank quickly and fire up without a problem (not often)
    *crank slowly and take and age to fire up (most of the time)
    *when driving in a morning and after work i find the blowers get faster the more RPM's the engine outputs then this stops after 3-5 mins or so
    the only way i can get it to start without taking a good few cranks is to turn the key and momentarily press the clutch down and it fires, starting with the clutch down from the off has no effect
    help, the car still has warranty until july, i will send it in for the work to be done but i would like a general idea of what is to be looked at as i don't trust dealers at all to get it right the first time, i work odd shifts driving buses so i need the car in and out within a day or two
    thanks
    kyle
    Feb 2013
    bolton
    Trim : mix& match
    Mileage : 91000
    anybody give me an idea with this?
    to add i have noticed when braking, even out of gear to a stop the engine seems to run slightly rough, then settles once stopped, again all other aspects of driving the car is superb, no power loss, i think my thermostat is trashed as the temp gauge rarley moves off the stop unless stuck in traffic, so ill be changing that
    Dec 2010
    London
    6 Post(s)
    Vehicle : Hyundai Ioniq Hybrid
    Trim : Premium SE
    Engine : 1.6 with 32KW motor
    Disconnect coolant temperature sensor and see if it starts any better then put it back on when started
    Feb 2013
    bolton
    Trim : mix& match
    Mileage : 91000
    i will try that tomorow, thanks
    Regular Member C-Owner's Avatar
    May 2011
    South London
    Quote Originally Posted by kylewareing View Post
    thanks
    kyle
    Have the Battery Starter motor and charging circuit checked by auto-electrical shop.
    Sounds like a bad starter motor to me
  1. starting issues
    By marc vectra sri in forum Vectra C / Signum Troubleshooting
    Last Post: 26th October 2012, 07:57
  2. Starting issues
    By jonny_adams60 in forum Engine & Drivetrain
    Last Post: 23rd February 2012, 00:02
  3. Starting issues
    By Fendy in forum Y & Z30DT Specific
    Last Post: 7th February 2012, 10:18
  4. Starting issues...
    By jones5n in forum Engine & Drivetrain
    Last Post: 9th October 2011, 18:29
  5. Starting issues !!!!!
    By Dimscreen in forum Engine & Drivetrain
    Last Post: 4th May 2011, 08:09
