Results 1 to 3 of 3
Thread: Would this fit?
    Feb 2011
    Mansfield, Nottinghamshire
    Default Would this fit?
    http://www.ebay.co.uk/itm/Vauxhall-V...item35c5e74d5c
    found these on ebay, would they fit as they look different attachments.
    thanks.
    Mark
    Jun 2011
    brum
    Deleted: Dupe'd the post when editing for some strange reason
    Jun 2011
    brum
    They don't show a picture of the connection open, but they look like the connection on mine when it's closed. As long as they are "retrofit" they will work. Basically inside that block is something akin to the looped connector you have on your standard blades. You just push the bar in, and hook it down over a U-shaped plastic thingymajig, then close the block cover and your done.
    Edit: Just realised i made the assumption that you have non-flat blades as standard. Of course if you have flat blades as standard, retro-fit one's won't work
