Thread: Rear Door won't open, how do fix?
    Nov 2012
    Perthshire
    Vehicle : Vectra SRI
    Engine : 2.2 16V
    Mileage : 78000
    Default Rear Door won't open, how do fix?
    Hi rear door has never open since I got car. Now failed MOT for this.
    2003 5 door SRI with manual rear windows.
    All the other doors and boot work fine.
    Managed to remove door card and tried cleaning the contacts of the solenoid, at the hinge. None of the rods move and have tried opening from inside and out.
    Bought new door switch/lock, when I pluged into my existing loom, it moves the rods as they should.
    With the door still locked, how do I take off the switch or open the door?
    Need quick answer, to take back for MOT
    Any suggestions please
    G
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    25 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    I take it the door wont open even if/when you raise the pin ?
    Nov 2012
    Perthshire
    Engine : 2.2 16V
    Mileage : 78000
    The pin won't raise at all. I have the complete door card off now but lock still engaged and does not want to budge, either from the external or internal handle.
    I don't want to burst open the door
    Is there another way?
    G
    Nov 2007
    DERBY
    25 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    If I've understood you the original lock/barrel is not engaging at all when you try and open it BUT the replacement works as it should?...Can you not disconnect the original and connect the new(I know you have already) also temporarily connect the new to the mechanics of the door internals?....maybe open it ?...
    Nov 2012
    Perthshire
    Engine : 2.2 16V
    Mileage : 78000
    By connecting the electrics to the new parts, I have established that the electric signal is getting to the lock. My issue is the lock stops the door from opening and normally the lock comes off by the 3 bolts which are accessed from the cpost.
    I am desparate for a solution where either I can remove the lock or open the door somehow.
    Any suggestions
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    If the lock will not function even with known good motor, cables, etc then that would suggest either a physical failure within the lock mech itself (unlikely, but not impossible) or the deadlock system is still engaged.
    However that said, it is worth confirming that with everything in place and the locks all opened from the driver's door control, is there any function at all from the problem door's outside handle? Outside handle, to remove childlock as being a problem.
    If not, it may take some manual operation of the cables, etc inside the door to achieve everything in the 'unlocked' position - you may want to take the card off the opposite door and compare with something that is actually working.
    Nov 2012
    Perthshire
    Engine : 2.2 16V
    Mileage : 78000
    The manual operation suggestion worked today. Managed to open the door at last!
    I could change the lock now, but it seems very fiddliy, so I will leave it for another day.
    The door now locks and unlocks manually, using the door button. that will get me through the MOT.
    Thanks to those would answered my call for help.
    Much appreciated
    G
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Glad to be of help.... that's why we're all here
  1. Rear door wont open
    By fingers66 in forum Bodywork & Interior
    Last Post: 11th October 2011, 15:06
  2. Rear door won't open
    By the_wave_rider in forum Bodywork & Interior
    Last Post: 8th May 2011, 14:17
  3. Rear door wont open
    By Jeffb in forum Bodywork & Interior
    Last Post: 13th February 2011, 21:06
  4. My rear door wont open
    By rhodod in forum Vectra C / Signum Troubleshooting
    Last Post: 4th December 2008, 22:34
  5. rear door won't open
    By daneboy35 in forum Bodywork & Interior
    Last Post: 22nd February 2007, 21:27
how to open rear drivers door if the solinord is broken on a vectra c
vectra c rear door wont open site:www.vectra-c.com
vectra c rear door lock
vauxhall signum rear door wont open
how to open rear drivers door manually if the solinord is broken on vectra c
Back door on vectra wont open
vectra c rear door lock stuck
opel vectra c deadlock stuck
how to open the back door opel vectra comby
