Results 1 to 10 of 14
Thread: Fumes Via Air Vents
    Leeds
    Vehicle : Insignia
    Trim : VX-Line
    Engine : BiTurbo
    Default Fumes Via Air Vents
    All,
    I'm sure I can detect a smell coming from my air vents when the car is started up, seems to clear when running but deffo a smell on start up. I'm sure I read on here (may have been gsi3.2) that their cdti had done something similar.
    Any ideas?
    Paul.
    P.S. I did run my aircon over the weekend as your supposed to every now and then, but it's more of a fumey smell than aircon eggy?
    Paul, I had Exhaust fumes in my cabin. It was traced to a faulty manifold and replaced under warranty.
    Not trying to teach you to suck eggs, but have you checked your pollen filter?
    Leeds
    Vehicle : Insignia
    Trim : VX-Line
    Engine : BiTurbo
    Quote Originally Posted by AJA View Post
    Cheers Alex, not checked pollen filter as i've only had the car 4 months, thought it would have been ok. Was your constant or just on start up?
    It was constant. Not so noticeable on the move, but once sitting in traffic it was horrible.
    Hertfordshire
    If it's a kinda damp musty type smell then go with the pollen filter first, then have the aircon system cleaned with anti bacterial stuff if it still persists.
    If it is more like exhaust fumes, then in Marks case I believe it was due to a snapped bolt in the exhaust manifold, meaning a loose seal, but this was caused when the turbo was changed.
    The turbo is part of the manifold on the 1.9's. Or that's what the stealer told me when he changed mine. Thank god it was under warranty.
    If the air cons not been run for ages Paul it will stink matey as you know.
    Hertfordshire
    Dunno m8, again I'm not over familiar with the engine, may be it was a bolt from the EGR valve that was snapped in the manifold.
    I didn't get the impression they are one unit though.
    I'm sure Mark will be along shortly to clarify.
    I'm here..LOL..
    yep, as GG has said, i've got our 150 in the stealers for that exact fault..the cabin was full of fumes and it gave my dad a real stinker of a headache.. i suggested he might like to stop gassing himself..
    So far VX have comdemned and authorised repair on the following..
    exhaust manifold
    turbo charger
    EGR link pipe
    DPF
    front exhaust section
    all gaskets and seals associated with it..
    and they're doing the swirl valve as a favour as it's started to P about as well, so new inlet manifold...
    The BAD NEWS is they've had the car over a week now waiting for bits, with still none in sight (anyone remember cara's gearbox?)..so i'm going to have to ask some more favours higher up the tree at VX..
    Paul, Get it in, and ask them to inspect the turbo, as it's a manufacturing fault apparently..just don't let them get too heavy with it as you may end up in a corsa like my old man..( new model...Horrid.. )..
    Vx had my car for three weeks (minimum) waiting for parts when mine was in for this. I believe the part they were waiting for was a gasket.
    Leeds
    Vehicle : Insignia
    Trim : VX-Line
    Engine : BiTurbo
    Thanks for the replies guys. I'm not getting constant fumes just a blast on start up from cold. I usually leave my blower setting on number 2 so it's on when i fire the engine up. Thing is i'm not sure what sort of smell it is.
    I have not run the aircon much in the 4 months but I gave it a good run over the weekend. If there is a coincedence with this, this is ties in with the smell. But how would you explain it when only from stationary, that's what makes me suspicous. I think if it persists over the rest of the week i'll get it booked in.
    I also have a second coincedence, i gave the car a good drive at the weekend really opened it up through all gears, I was doing about 70 in 3rd so the smell coincides with quite a few things.
    I was talking to my parts guy this aft and he said Vauxhall are having to borrow the turbo's and manifolds from Saab now. He has had 4 different part numbers in the last couple of weeks for other Veccys having similar probs.
    Paul.
  1. fumes inside car
    By neil52 in forum Engine & Drivetrain
    Last Post: 6th April 2013, 08:59
  2. face lift chrome vents and rear vents
    By simon1 in forum Vectra C / Signum Car Chat
    Last Post: 21st December 2011, 21:13
  3. Fumes
    By stevie16v in forum Engine & Drivetrain
    Last Post: 19th September 2011, 21:08
  4. Fumes Entering Through Vents
    By s-owen4 in forum Engine & Drivetrain
    Last Post: 30th January 2011, 17:36
  5. Fumes In The Cab - Help!
    By MRLUBBERLUBBER in forum Vectra C / Signum Car Chat
    Last Post: 25th October 2008, 19:27
