Thread: Headlights dirty inside wth!
    Nov 2012
    london
    Vehicle : Vectra c facelift flame red
    Default Headlights dirty inside wth!
    Hi people! the inside of the my headlights are really dirty. Is there any way I can clean it up. It's all dull in there! I don't know how it happened. So depressing =(
    13 Post(s)
    Are you referring to the silver reflector surface or the projector domes?
    If the latter, then they all have that cloudy appearance about them.
    Nov 2012
    london
    Yup the silver reflector surface. It's got water marks everywhere. Can I take the headlight off and rinse it out like a bottle?
    Regular Member puppet's Avatar
    East Ayrshire
    10 Post(s)
    Vehicle : Insignia 1.8 SRi
    Trim : VX Line Red
    Engine : 1.8VVT
    Year : 2011
    Quote Originally Posted by drmak1992 View Post
    I've done that previously with some preface headlamps, and it worked a treat. Took mine out and gave them a really good rinse out under the tap. What I would say though is don't use too warm water, as it strips the silver coating off of the reflector surfaces.
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Also, if you have the option, use filtered water - put through a jug filter or similar. That way you should reduce anything left behind.
    Your other option of course is to remove and strip the headlamp units, then clean everything thoroughly, before reassembly. Hard job perhaps, but it means you can be sure everything is clean, dry and mark free.
    Nov 2012
    london
    Quote Originally Posted by Handyandy-UK View Post
    How do you strip it up? Does it come apart or do you need to put it in an oven? Lol
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Normally, the lens is secured to the body of the unit with an adhesive mastic - was a pig to seperate on Omegas but I believe one or two on here have managed Vectra lamps without breaking anything, while fitting LED DRL strips (Daylight Running Lamps).
    Nov 2012
    london
    Cheers buddy much appreciated
  1. drls fitted inside headlights
    By topgun in forum Styling
    Last Post: 22nd March 2010, 18:24
  2. Headlights have gone foggy inside..
    By bobby-tupper in forum Vectra C / Signum Car Chat
    Last Post: 8th December 2008, 20:38
  3. Is this dirty??
    By shatz in forum Vectra C / Signum Car Chat
    Last Post: 6th December 2008, 17:33
  4. dirty car
    By scottyd in forum Vectra C / Signum Car Chat
    Last Post: 8th November 2008, 13:29
  5. How Dirty Is Your........
    By VectraMat in forum Vectra C / Signum Car Chat
    Last Post: 24th December 2007, 17:01
how to clean inside vauxhall astra headlights
clean inside car headlights vauxhall vectra
Astra h clean out inside of headlights
astra headlight dirty inside
clean opel vectra headlight inside
dirty lens of the lamp vectra
how to clean vectra c headlights
clean inside headlight vectra
opel astra h cleaning headlight inside
vauxhall signum dirty headlight
2004 vauxhall astra headlights how to clean inside them
how to clean inside headlight vauxhall astra
vectra c fogged headlights
astra j clean inside headlight
vectra c headlights fogges
how to clean the inside of astra h headlights
vectra c inside headlight clean
cleaning inside of vectra c headlights
will astra headlamp fit signum
