Thread: Coolant temp symbol flashing and temp gauge maxed out. ... HELP
    Jan 2013
    Bedlington
    Default Coolant temp symbol flashing and temp gauge maxed out. ... HELP
    temperature gauge just maxed out and symbol flashing, however the engine isn't red hot and the fan is blowing cold, could this just be that I need a new thermostat/sensor or is it worse. anyone that can help or has had this problem it would be greatly appreciated,
    car is 07 reg. 1.8 SRI
    CHEERS
    Regular Member Gubmint Agent's Avatar
    Feb 2011
    Feels a lot like Kathmandu.
    Trim : Sri
    Engine : 2.2 Direct
    When this happened on my old car (VW Passat) the water pump had failed. Exact same scenario.
    Regular Member stevoxsi's Avatar
    Sep 2012
    Coleraine, Norn Iron.
    Vehicle : Insignia
    Trim : Sri Vx-line
    Engine : 2.0 Cdti 160
    Year : 2011
    Sounds like water pump to me too. If seized it can take out the timing belt, so don't start the engine.
    Mar 2013
    liverpool
    Vehicle : '04 (54) vectra sri cdti 120
    Trim : sri
    Engine : z19dtl
    Mileage : 178000
    Does this happen as soon as the ignition is turned on? I.e engine cold, as it could be a faulty sensor. Have you had any work done on the cooling system recently? As it could have an air lock, most vauxhalls dont have any bleed screws so air licks are easy to get
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 85000
    With the engine running take the cap off the header tank, you will see coolant returning to the header straight away. If there is no water returning id say definitely the water pump too.
    Jan 2013
    Bedlington
    Cheers guys, I'll try get this sorted ASAP. bank holiday weeknd aswell, just my luck
    jiffy1986 .... Yes it's happening from cold, but when it happened I'd been driving for few mile, pulled into
    house and onto the driveway, then I heard the fan blasting away. hopefully warranty covers it,
    thanks for the help,
    Jul 2015
    Cowdenbeath
    Vehicle : Vectra C Sri
    Trim : Hatchback
    Engine : Z18XER
    Hi. I have exactly the same problem. Did it help ? I cannot start my engine. On cool start gauge shows max temp.
    Wysłane z mojego SM-N9005 przy użyciu Tapatalka
    North West - Assistant RO Woody's Avatar
    May 2012
    North West (Warrington)
    234 Post(s)
    Vehicle : Vectra C 3.2 Elite Estate Auto Facelifted
    Trim : Elite with loads of "Extras"
    Engine : 3.2 Z32SE
    Mileage : 94,000
    Get a codereader plugged in !!!!
    HTH
    Jul 2015
    Cowdenbeath
    Trim : Hatchback
    Engine : Z18XER
    No ecu connection appears on opcom. I've replaced coolant temp sensor and tepm gauge dropped from max to 92 ish. The same as normal during driving. I have new thermostat replace it to?
    Jul 2015
    Cowdenbeath
    Trim : Hatchback
    Engine : Z18XER
    And I've plugged in autel reader. Doesn't show any errors. lol but let's me to switch off mil light. For a second. Now I have mil, abs, cim light on a dash 92 on the temp gauge and no starting. There is a torque but not start
  1. Temp Gauge not working - temp sensor - thermostat? help!
    By scourslane in forum Engine & Drivetrain
    Last Post: 7th March 2013, 21:17
  2. signum 2.0t coolant loss and faulty temp gauge
    By catbic in forum Engine & Drivetrain
    Last Post: 25th July 2011, 09:42
  3. engine coolant/temp gauge/heater
    By redmoog in forum Engine & Drivetrain
    Last Post: 1st December 2010, 21:37
  4. engine coolant/temp gauge/heater
    By redmoog in forum Vectra C / Signum Troubleshooting
    Last Post: 1st December 2010, 21:27
  5. coolant temp gauge
    By KeefyB in forum Vectra C / Signum Car Chat
    Last Post: 23rd January 2010, 12:10
position of coolant temp senders on vectra c z18xer www.vectra-c.com
vectra c temp gauge goes to red as soon as ignition on
vectra c z18xer temperature sensor locations www.vectra-c.com
vectra 2.0t temperature gauge issue site:www.vectra-c.com
