Results 1 to 10 of 17
Thread: vectra 1.9 cdti 120 bhp 8v engine vibrating rattling shaking
    Sep 2012
    Teesside
    Post vectra 1.9 cdti 120 bhp 8v engine vibrating rattling shaking
    hello car is a taxi, on start up the engine rattles/shakes have made video. and there is also blueish smoke out the exhaust, after revving the engine, its fine, no power loss no lights etc.
    will post on you tube or try to upload on here
    Oct 2012
    Ashford, Middlesex
    welcome to the club my friend, this is a common fault which no one seems to have found a fix for :-(
    Regular Member Vectra Adz's Avatar
    Jun 2012
    Kent!
    Vehicle : SXi+
    Trim : GSi Spec
    Engine : 1910
    Mileage : 140k +
    Mine does this to..... only sometimes i will add.... strange lol... i just ignore it lol
    South Central England
    18 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Might be a weak battery or worn piston rings
    Regular Member bex879165's Avatar
    Feb 2013
    Halifax
    Engine : 1.9CDTi
    I haven't got the blue smoke and mine only does the shaking thing when it's extreme freezing conditions outside. Just a normal cold morning it's fine. It does white smoke on start up most of the time though.
    Sep 2012
    Teesside
    thanks guys, this is the 2nd engine in the car first engine never done this and that had about 260k.
    Regular Member Craig1985's Avatar
    harwich essex
    Mines started doing this, only got 30k on it tho
    Sep 2012
    Teesside
    There must be someone who had this problem and found a solution...
    could it be something to do with glow plugs as its only on start up?
    Mar 2013
    liverpool
    Vehicle : '04 (54) vectra sri cdti 120
    Trim : sri
    Engine : z19dtl
    Mileage : 178000
    Almost certain it will be one or more glow plugs down. Unplug them and do a resistance check on each plug with a multimeter set to ohms. Put the red lead on the terminal of the glow plug, and the black lead to a suitable earth point (engine block, battery neg etc). You should see a reading of no more than 1.5 ohms. The usual reading is about 0.7 ish. If the multimeter does nothing, the plug is in open circuit and needs replacing, or if its any more than 1.5 ohms it has a high resistance.
    Regular Member Angel1368's Avatar
    Mar 2012
    liverpool
    34 Post(s)
    Trim : VXR
    Engine : 2.8 V6 turbo
    Mileage : 44,000
    mine also does this, ive just chucked in a bottle of redex heard may do the job
  1. Car / engine shaking
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 15th June 2016, 19:14
  2. Engine Shaking the whole car
    By inchy1981 in forum Engine & Drivetrain
    Last Post: 17th December 2012, 14:34
  3. Shaking/vibrating chassis a
    By tmug in forum Suspension, Wheels & Brakes
    Last Post: 14th January 2011, 21:17
  4. Engine Shaking 2.2 Direct
    By Sean-2.2Direct in forum Engine & Drivetrain
    Last Post: 28th May 2009, 16:59
  5. What causes a rattling in the engine in a Vauxhall Vectra?
    By paulh in forum Engine & Drivetrain
    Last Post: 13th November 2008, 07:43
vectra c 1.9cdti rattling from pulleys
vectra c cdti sri engine rattles
cdti vibrating engine vauxhall vectra
rattle from engine on start up vectra 19 cdti
