Results 1 to 10 of 15
Thread: What is this black box? And broken Pipe?
    Notts
    Default What is this black box? And broken Pipe?
    Hi all,
    I have a vectra 1.9 120. While changing glow plugs, and tightening the fuel line I managed to snap the following pipe (2):
    See the image here:
    1) What is this box?
    2) I have managed to snap that pipe right at the base where the arrow ends.
    The car drives normally but turbo doesn't spin up like it used to. Im guessing it has something to do with compression, I want to replace the black box + piping to fix the issue but dont know what it is to buy the part!
    any input from anyone?
    thanks
    Regular Member Ozyboyross's Avatar
    Oct 2012
    Sprowston, Norwich
    6 Post(s)
    Trim : SRi XP
    Engine : 1.9 CDTi 150
    Mileage : 90k
    I think there the vac lines.....
    Regular Member d_ghedia's Avatar
    Oct 2007
    Berkshire
    Vehicle : Vauxhall Signum
    Engine : 1.9 CDTI 150. Manual
    Looks like a vacum pipe so related to air. Could be wrong tho.
    Chelmsford
    Agreed, vacuum pipe...
    Regular Member ftm100's Avatar
    South Shields seagull sh*t town
    Regular Member C-Owner's Avatar
    May 2011
    South London
    Remove the Vacuum box and super glue the pipe back on until you replace the part with a new one .
    Call Vauxhall with your VIN number and identify the part correctly, it should be GM55187748 as posted above
    Quote Originally Posted by Nucleo View Post
    Hi all,
    See the image here:
    thanks
    Feb 2012
    sheffield
    Vehicle : SIGNUM 1.9 CDTI ELITE
    Trim : ALL OPTIONS ELITE
    Mileage : 140,000
    it is a non return carbon filter that the vac lines go into, completely remove the pipes from the box altogether, follow the metal pipes (that the rubber ones connect to) to the front of the engine and you will see these metal pipes have rubber pipes on the end, one goes to the boost solenoid (on top of the radiator) and the other to the vac pump.
    Take note of the circuit all these pipes take and simply use some of the rubber pipe you removed to connect the pump to the solenoid and the solenoid to the pipe that goes down to the turbo actuator.
    The box really does not do anything as on the later engines it is not there!
    cheers.
    Feb 2012
    sheffield
    Mileage : 140,000
    p.s. I did this mod on mine after breaking the plastic joint you mention and it absolutely works!
    And incidentally I broke the filter box open and it was absolutely clean.....my car (150 cdti 2005 140k) is still running great after a 1000 or so miles.
    Feb 2012
    sheffield
    Mileage : 140,000
    Firstly try the mod and if you are still not happy and want to fit a new box then let me know as I brought a spare box in panic when I broke mine but in the mean time between delivery I just did the mod and all worked fine,in short you are welcome to the spare box I have !
    Feb 2012
    sheffield
    Mileage : 140,000
    ....oops forgot to mention.........superglue or any other glue will not work on that type plastic !
  1. EGR offtake pipe (turbo to egr cooler pipe) - Part# ?
    By jonnyaykroyd in forum Engine & Drivetrain
    Last Post: 3rd March 2013, 01:29
  2. Black soot around exaust pipe
    By TopRod in forum Detailing and Car Care Discussion
    Last Post: 5th July 2011, 11:04
  3. broken egr pipe and blanking it off
    By coooky in forum Engine & Drivetrain
    Last Post: 14th June 2011, 20:13
  4. black smoke and intercoler pipe
    By 123ashleyp in forum Vectra C / Signum Car Chat
    Last Post: 17th July 2010, 12:55
  5. Exhaust-Flexi-Pipe Broken
    By Dreamyhose in forum Engine & Drivetrain
    Last Post: 16th October 2008, 09:27
https:www.vectra-c.comforumshowthread.php184457-What-is-this-black-box-And-broken-Pipepage2
gm engine what is the black box on rear of engine with vac pipes
vectra snapped flexi
vectra c engine round black box
vectra c 1.9cdti 120 engineturbo pipe
vectra c 1.9 vac pipes
