Results 1 to 10 of 17
Thread: My gear stick knob keeps springing off!
    Regular Member cardiffgareth's Avatar
    Mar 2013
    Vale of Glamorgan
    Vehicle : Vectra C 1.9 CDTi 120bhp 8v
    Trim : Life
    Engine : 1.9 CDTi
    Default My gear stick knob keeps springing off!
    What's the best way to secure it in place? 4 times its come off now, always when driving! Was gonna super glue it on but thought a piece of blue tac might work just as well and it's not permanent ?!!
    Jun 2011
    brum
    everyone has there own methods (it's a common issue, don't worry). Blue tac probably won't do it, you have a number of options:
    1. Glue it - Will make it a pain in the rear to get off if you ever want to switch it out, but it should still come off with brute force if you use the glue sparingly (a single dot or two on the shaft should do it).
    2. thicken the shaft (hehe) - use something to wrap round the gear shaft so its a tighter fit. possibly some card (not cardboard!), then just add as many wraps as you need until it stops popping off on you. Ofcourse this method could be more permanent than the glue if you make it too tight of a fit, so be careful.
    I happened to have some loc-tite (blue i believe) in my centre console (bought it in prep. for a disc change). So when it came off on me for the Nth time, i opened that up and chucked a fair bit inside the knob (oh so many innuendo's, i need to grow up) and whacked it back on. Never had a problem since and i don't intend to replace it anyway
    Mar 2013
    Vale of Glamorgan
    Trim : Life
    Engine : 1.9 CDTi
    Thanks!
    Glue it is then!
    Regular Member Gubmint Agent's Avatar
    Feb 2011
    Feels a lot like Kathmandu.
    Trim : Sri
    Engine : 2.2 Direct
    Bathroom silicon sealant worked for me.
    Regular Member dilan's Avatar
    Aug 2009
    dudley, west midlands
    Swap it for an Astra gearstick... No more springing off and looks loads better..
    Mar 2011
    n. ireland
    welcome to the home of jumping knobs, iv,e got one as well
    Sep 2009
    midlands
    i used chewing gum haha, it was allright until it got really hot in the car, it sprung off and left super strings of sticky gum everywhere.
    Oct 2011
    Stoke on Trent
    I used some resin glue (araldite) and a mallet to make sure it sat on it it's proper place as it sat a little higher than it should. Don't do what I did and give it a good wack will a mallet and crack the top of the gear knob jewel, to later find it can be easly oved with a small flat blade screw driver and reveal a nice flat metal plate, perfect for wacking!!!
    Full Member Z80's Avatar
    Apr 2008
    Noumea
    16 Post(s)
    Vehicle : Opel Vectra GTS
    Trim : Elegance
    Engine : 2.2 DTi 16V
    Mileage : 75 000
    Seriously, jump on the occasion to fit a better looking (and most important, better feeling under the hand) one.
    Aftermarket knobs are fitted using a transversal grub screw to tighten it to the shaft, so it won't pop off anymore.
    Else, just hammer it down. The original knob hole is slighty conical, so the harder you push it down, the better it will stay in place. People generally have problems removing it, actually.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Get a VXR/XP2 gearstick altogether.
  1. new gear stick knob
    By marko1973 in forum Styling
    Last Post: 23rd August 2012, 22:08
  2. gear stick/knob
    By farley2708 in forum Bodywork & Interior
    Last Post: 2nd January 2011, 15:47
  3. Vec-C Gear Knob onto Vec-B Stick??
    By Vaux-Man-G in forum Vectra C / Signum Car Chat
    Last Post: 24th April 2009, 21:24
