Thread: Injector Copper Washer Question?
    Hanging Heaton
    35 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 140k
    Default Injector Copper Washer Question?
    So... I resat them using the cutting tool, even threw in a smidge of gasket sealant for good measure and number 2 has started to bubble slightly again...
    Has anyone tried non vauxhall washers, maybe of a slightly thicker size, like .5 or 1mm so they compress better?
    Also this time just gone number 2 was completely caked in carbon, took ages to losen and move and was the only one where the clamp bar bolt came away from the head side... I wonder if crap got down the thread hole and its sat a tad higher, can anyone remember if there's a break in the thread on these bolts or are they threaded full length, pretty sure there's a break?
    Regular Member neill's Avatar
    Nov 2009
    Warrington
    Vehicle : Vectra C estate
    Trim : SRI
    Mileage : 79000
    Everytime ive changed injector seals ive always changed the washers that sit on top of the clamp, there conical in shape and look like this
    Part number 93179049 x 4
    These washers squash slightly once the nut is torqued down, and because the stud has a thread gap, the nut tends to reach the thread gap. Which then gives you a faulse torque and in turn causes the injector to leak.
    As for using different washers id just stick with vx ones m8, they do the job well as long as everything else is good, ie the stud is screwed in fully and tight and also as above.
    HTH
    Regular Member C-Owner's Avatar
    May 2011
    South London
    I cringe every time I hear people re-cutting thier injector seats because 99% of the time its not necessary.
    IMHO
    1. Injector seats need polishing to a highly smooth finish for a perfect seal.
    2. Injector seals should never have any form of sealant applied to them
    3. Fuel injectors reqiure specific tolerances in the combustion chamber any cutting/thicker washers/sealing compounds can compromise this.
    Hanging Heaton
    35 Post(s)
    Mileage : 140k
    Only recut this time as it was the 3rd attempt to rectify this... Never replaced the top washer, just the seals and new steel nuts, may have not torqued them up enough however... Actually just on with it now...
  1. Injector seals question
    By SlowCoach in forum Engine & Drivetrain
    Last Post: 8th February 2013, 00:07
  2. Injector question
    By gaz1965 in forum Diesel Engine related
    Last Post: 5th February 2013, 13:58
  3. 1.9 injector washer problem
    By Derv-head in forum Engine & Drivetrain
    Last Post: 14th January 2013, 13:47
  4. Saab and Vauxhall fuel injector question...
    By n_hudson in forum Vectra C / Signum Car Chat
    Last Post: 17th June 2010, 19:37
  5. Headlamp Washer Question
    By redraptor_141 in forum Electrical & ICE (including SatNav)
    Last Post: 16th May 2009, 22:56
https:www.vectra-c.comforumshowthread.php184449-Injector-Copper-Washer-Question
copper washer between injector and head
function of copper washer
functions of copper washer
z19dth injector studs
Two functions of copper washer fitted
functions of copper washer in the diesel injectors
function of the copper washer
functions of a copper washer
what are functions of copper washer situated between the injector and the cylinder
function of injector copper washer
how to re seal injectors on vauxhall vectra cFunctions of the copper washer reffered injector and the cylinder headWhat is the function of copper washer what are the two functions of the copper washer fitted between injector and cylinder headfunctins of coppr washer that is fitted between the injector and cylindee headfunction of a copper washer between the injector and the headfunctions of the copper washer situated between the injector and the cylinder headfour functions of copper washer situeted the injectir and cylinder headfunctions if a copper washer fitted between injector and the cylinder headstate two functions of the Cooper washer that is fitted between the injector and the cylinder headz19dth stuck injectortwo functions of copper warsher in injector and cylinder headExplain two functions of the copper washer on a diesel engineFunctions of a copper washer under the injector
