Thread: couple of questions
    Regular Member andy_richmond's Avatar
    Sep 2012
    andover
    Trim : sri
    Engine : 2.2 dti
    Default couple of questions
    2.2 dti vec c
    first, the boot has just a button, if my now dead car sits for a while and the battery goes, is there a way to open the boot???
    second, can i get away with changing the thermostat without draining all the coolant, how much will i lose from the 2 hoses and block??? or is it best to drain it. its just been changed and the thermostat has died
    Regular Member azacbr6's Avatar
    Dec 2010
    chesterfield
    In answer to first question, no, if battery completely dead, and you're not able to use central loccking then you can't manually open your boot unless you leave it open to start with. why don't you lock the car with the remote and then disconnect the battery to keep it alive and reconnect it to open your boot.
    second question, not sure how much you lose but apparently not a lot, someone who's done their thermostat will advice I am sure.
    Wigan
    Trim : Exclusive
    Engine : 1.9 CDTI
    I can't remember losing that much coolant when I did my thermostat. Might be about a litre at a guess. I think I lost everything in the top of the block above the thermostat housing but I'm sure my expansion tank didn't empty.
    Sep 2012
    andover
    Trim : sri
    Engine : 2.2 dti
    thanks guys, i have 2 ltrs of gm antifreeze left, so might risk it
    one more thing, i want to try and preserve the car, but theres half a tank of derv in there, can i get it out of the filler with a hose, or do modern cars stop this now.
  1. couple of questions
    By vec150 in forum Vectra C / Signum Car Chat
    Last Post: 4th February 2013, 17:32
  2. Couple of small mods (Pics) and a couple of questions
    By bigdan in forum Electrical & ICE (including SatNav)
    Last Post: 30th January 2009, 18:18
  3. Couple of questions.
    By Stuarty in forum Vectra C / Signum Car Chat
    Last Post: 14th January 2008, 08:16
  4. couple of questions
    By SteveH in forum Vectra C / Signum Car Chat
    Last Post: 19th August 2006, 11:11
