Results 1 to 10 of 11
Thread: P1625-58 Main Relay Opens Too Early
    Regular Member justin32's Avatar
    Aug 2011
    Basingstoke
    5 Post(s)
    Vehicle : Vectra c SRI Facelift
    Trim : SRI
    Engine : 1.9 CDTI 150
    Default P1625-58 Main Relay Opens Too Early
    Hooked my car upto op-com today as the cra keeps cutting out on cold start up and after 4-5 times the spenner light comes on and the car goes into limp mode.Once the car has warmed up a bit i can switch off the engine and start up and everythings fine.
    the code i got was:
    P1628-85 Main Relay Opens Too Early
    Can anybody help me out and point me in the right direction what to check and look out for?
    Dec 2011
    Seaham
    What engine is it??
    Aug 2011
    Basingstoke
    5 Post(s)
    Trim : SRI
    sorry its a z19dth
    Dec 2011
    Seaham
    Does the glow plug light come on and stay on for 10-15 seconds, before you try to start it?
    Aug 2011
    Basingstoke
    5 Post(s)
    Trim : SRI
    yes sometimes id does do that but not all the time.I had 3 new plugs not long ago so i dont think its them.
    What is the main relay anyway? been googling and it can be the ECU?
    Aug 2011
    Basingstoke
    5 Post(s)
    Trim : SRI
    i meant to say that yes the light does come on but only after the car has cut out.before it cuts out the light comes on for a few second then goes out like it should....Ive also had the power steering light comes on after its cut out but that goes away when i restart the car
    Also forgot to mention the car feels like a bag of spanners when its cold and kind of feels like its only running on 3 cylinders untill limp mode sets then then it starts and stays running albeit on limp mode untill the car warms up
    Regular Member Vulf86's Avatar
    Aug 2013
    Doncaster
    5 Post(s)
    Vehicle : V6 Elite
    Trim : VXD
    Engine : 3.0 CDTi V6
    Reviving an old thread here. but did you ever get a solution for this? Got this code myself this morning
    Sent from my D6603 using Tapatalk
    VIP-Member sulten's Avatar
    Øvre Årdal, Norway
    13 Post(s)
    Vehicle : Opel Vectra C
    Trim : Cosmo OPC Line
    First try should be to try check/changing K2 relay in UEC.
    You can also check the contacts at the relay, UEC and ECU for corrosion.
    If this not help you might have a faulty ECU or UEC.
    Kristian
    68 Diplomat-A 46S
    95 Vectra-A C20NE
    07 Vectra-C Z19DTH
    Aug 2011
    Basingstoke
    5 Post(s)
    Trim : SRI
    Quote Originally Posted by Vulf86 View Post
    Hi mate,
    nope ive never got to the bottom of this after 4 years of owning the car :-(
    Due to only having this problem when its cold it kind of slips my mind until the temp drops and it starts playing up again.I will however be investigating it further until I find out what the problem is
    Just out of interest is it just the code your getting or is it all the other stuff that goes with it i.e cutting out,limp mode and dials not working?
    Aug 2011
    Basingstoke
    5 Post(s)
    Trim : SRI
    Quote Originally Posted by sulten View Post
    will check them out
  1. Electric tailgate opens itself
    By lastyboy in forum Bodywork & Interior
    Last Post: 10th November 2013, 19:42
  2. Bonnet opens on its own.
    By phant in forum Vectra C / Signum Car Chat
    Last Post: 28th May 2012, 23:05
  3. boot opens when the car is unlocked, but....
    By Blurry120 in forum Electrical & ICE (including SatNav)
    Last Post: 22nd March 2012, 14:05
  4. Central locking opens boot
    By littlecretta in forum Electrical & ICE (including SatNav)
    Last Post: 11th March 2009, 18:30
  5. Santa Pod opens again next Sunday!
    By nutron in forum Vectra C / Signum Car Chat
    Last Post: 15th January 2007, 11:29
p1625 vauxhall
Vauxhall P1625
p1625 vectra
OPEL P1625-00C
p1625 main relay
p1625-58
p1625 opel corsa c
main reley opens too early
Opel DTC P1625-A
opel meriva main relayOpel DTC P1625-COpel P1625-5p1625 opelp1625 opel vectraOpel P1625-58Opel DTC P1625-58vectrac.com vectra cdti limp mode when cold www.vectra-c.comp1625 opel zafirap1625 opel corsavauxhall main relayp1625 vauxhall zafiraOpel DTC P1625-2p1625-C on vauxhaul combo dieselDTC P1625 OPEL corsa dieselvauxhall fault code p1625
