Thread: notchy steering
    Mar 2011
    guildford
    Default notchy steering
    hi i have a 2005 vectra sri auto and first thing when the car is started and i pull away there is a really notchy feel to the steering when turning in either direction,it is quite bad.when driving for a bit it doesnt make the noise.any suggestions what this could be?i have changed the front droplinks.
    cheers
    Regular Member blue estate's Avatar
    oh well.. I tried..
    Checked the level of the steering fluid? Mine was low and had the same feeling til i topped it up
    Mar 2011
    guildford
    cheers i will check that tomorrow.
    iIt only happens for the first couple of turns of the wheels and then the notchy feels goes away which is weird.
    Mar 2011
    guildford
    found that there was no power steering fluid in the bottle so filled up and all is good with the steering now
    oh well.. I tried..
    Just check it again in a couple of weeks to make sure level is ok
    Mar 2011
    guildford
    cheers.i found a tiny hole in the steering rack gaiter so i think it has been leaking out of that for a while.would you know how easy it is to change the gaiter or a rough price to get it done in a garage?
  1. notchy 2nd gear
    By eminemme42 in forum Engine & Drivetrain
    Last Post: 15th March 2012, 23:43
  2. notchy gearbox
    By tecg in forum Engine & Drivetrain
    Last Post: 8th December 2011, 22:47
  3. Notchy steering- cheap fix for once.
    By Clive J in forum Vectra C / Signum Car Chat
    Last Post: 25th January 2011, 21:37
  4. Notchy Gearchange
    By BigP in forum Engine & Drivetrain
    Last Post: 1st February 2007, 20:11
  5. Notchy Gears
    By Martyn21 in forum Vectra C / Signum Car Chat
    Last Post: 16th May 2006, 14:23
