Thread: traction controll
    Mar 2013
    sheffield
    Vehicle : vectra
    Trim : elite
    Engine : 3.0 cdti
    Default traction controll
    i have a 05 elite 3.0 cdti , the abs light and traction warning triangle has come on the instrument cluster , i just bought the car with the warning light already on , any ideas ??? also i have no button to turn on or off this traction controll on the dash board should i have on as ive seen cars with the button on dash ??????
    12 Post(s)
    Ideally you need the fault code(s) reading out, but as both the ABS and TC light is on, it pretty much sounds like a wheel sensor is at fault. Having the codes read out should identify which one(s)
    You can fit a button yourself into the blank where it would normally go. It's hit or miss whether it'll work though. Depends if it's wired up behind the panel.
    Feb 2011
    Selby
    If you just bought the car, take it back to where you got it from. Selling a car with a fault light lit is highly dodgy, and the responsibility of the seller to fix.
    12 Post(s)
    Quote Originally Posted by rich r View Post
    Unless it's been bought as seen and tested from a private seller.
  1. Has anyone got a climate controll resistor or know where I can get a second hand one
    By CallumHill in forum Vectra C / Signum Troubleshooting
    Last Post: 28th December 2012, 20:29
  2. traction controll switch
    By dansri in forum Vectra C / Signum Car Chat
    Last Post: 17th November 2010, 01:37
  3. Traction controll
    Last Post: 13th November 2009, 19:32
  4. BC with CD30 and GID cant controll anything
    By blakewp in forum Electrical & ICE (including SatNav)
    Last Post: 11th February 2009, 00:43
  5. Traction controll button
    By lindsay1411 in forum Vectra C / Signum Car Chat
    Last Post: 12th August 2007, 01:38
