Thread: signum fog light grills fintment?
    Regular Member Del101's Avatar
    Dec 2012
    York
    Default signum fog light grills fintment?
    I have bought my self some signum fog light grills for my facelift vectra, does any one a have a thread on how to fit them?
    Andy
    Regular Member mrk's Avatar
    Vehicle : vectra hatchback
    Trim : improving
    Engine : 1.9cdti mas remap
    Year : 06
    iirc spoons did a how to ages ago,hard bit is getting the old ones off,small bit of plastic weld on the tabs-easy to see from behind once bumper is off.new ones just bang on with heel of your hand,got mine to swap but i've got to mess about lining up non oe fogswith halos,that i've lashed some brackets up for .
    Regular Member Gubmint Agent's Avatar
    Feb 2011
    Feels a lot like Kathmandu.
    Trim : Sri
    Engine : 2.2 Direct
    Some people reckon that you can just pull out the old ones from the front without having to remove/drop bumper but I found that they were held in by (as above) small melted plastic tabs. I had to drop the bumper and cut these with a Stanley knife. Once the old grilles are out the new ones did just clip back in with a little help.
    Regular Member ThatAudioBloke's Avatar
    Feb 2013
    Newcastle, UK
    20 Post(s)
    Engine : CDTI 150
    Mileage : 103000
    Anyone have the part numbers for the signum surrounds? I'm tempted by them, and as I'm looking at a HID kit I'd prefer to get everything done and dusted in one rather than have to take the bumper off loads of times.
    Feb 2011
    Trim : Sri
    Engine : 2.2 Direct
    99% sure they are 93187823 and 93187831. At least one of those is currently available from a dealer via Carpartsconnexion for £11.70, I've just found, and the other can be had for £19.50 from genuinepartsearch.
    Trim : improving
    Year : 06
    if you get the pair for less than £50 you've got a bargain m8
    Feb 2011
    Trim : Sri
    Engine : 2.2 Direct
    Oh yes, my pair cost me £26 inc delivery from carpartsconnexion.
    Feb 2013
    Newcastle, UK
    20 Post(s)
    Engine : CDTI 150
    Mileage : 103000
    Nice one, cheers!
    Jun 2011
    Buckley Flintshire N.Wales
    Vehicle : vectra
    Trim : .....................
    Engine : ....................
    Year : .....
    I was one of the lucky ones just pulled the old ones off and clipped the new ones in took me 10 mins tops,and they cost of £30 delivered so they were a bargain too
    Regular Member H20JOE's Avatar
    Feb 2013
    Kilsyth, United Kingdom
    Trim : Sri
    Engine : 1.8
    Mileage : 59000
    Just did mine today didnt have to take the bumper off like spoons did it from underneath the car just take the 2 bottom 8mm bolts that hold the foglight to the bumper then pop the old grill off from behind. I found it easy to use one hand through the foglight hole to pull while using the other to push the clips out.
  1. Signum Fog Light Surrounds / Grills
    By n_hudson in forum How much is it worth? (THIS SECTION IS NOW CLOSED)
    Last Post: 27th January 2009, 15:05
