Well after the problems ive had with the new car with the turbo and intercooler now a HUGE problem has happened, got in before turned the key she fired up fine but then a warning come on that said, front parking light out, god when will it all end![]()
Is that the one that requires the front bumper removing to fix?![]()
Which one did it show was out mate?
easy enough to change. An nice excuse for LEDs
bumper offcritch you are bad lol its the front passanger
I've done both sides with out removing the bumper...remove airbox for o/s and remove screenwash filler pipe to do n/s.....on a pre face sri
(just to come clean, I was being sarcastic hence thesmiley! )
Should be able to do the sidelights by either moving the airbox or opening the battery box and pop out the filler pipe, depending on what side has gone!
Put some EBay LEDs in my sidelights, they werent CANBUS-friendly as stated so now I just have to cancel the 'bulb out' warning every start-up. Look much better than the yellow halogens though even if bumper did have to drop to fit them.
