Thread: Smoke from bonnet, burning smell, but just once?
    Regular Member SteveBray's Avatar
    Barnsley, South Yorkshire
    confused Smoke from bonnet, burning smell, but just once?
    I have a 12 plate bi-turbo sport tourer with AFL Xenons and on a recent trip after returning home there was a bad burning smell and smoke coming from under the bonnet. I lifted the bonnet and the smoke stopped but still a slight burning smell, left the car alone and looked later and everything appeared fine. It has not done this since, has anyone else had this?
    I also have a noisy rear passenger window that needs a new seal or something but Evans Halshaw say no, they can't hear it. I also get a range of small creaks but they seem different every time I drive, I like the drive and the seat is brilliant but not sure I entirely trust the car and would not want to own it out of warranty.
    Regular Member 3.2_V6_VXR's Avatar
    S.Wales, Nr Swansea
    Could possibly be EGR cooler housing mate, thats what happened to mine, if you pop the bonnet and get someone to rev the car over 3000k revs it should squirt water over the exhaust manifold, its located left of the battery tray, fingers crossed its just that for you lol
    Thanks, I will have a look and give that a try, only a year old and 10,000 miles done.
    S.Wales, Nr Swansea
    EGR cooler is quite a common problem now
    Regular Member tpj2012's Avatar
    May 2012
    skegness
    I had one do that it was clamp near turbo not on properly every time it went in to regen it poured smoke out bit scarey to start with get them to look at that as well
    Regular Member keith1983's Avatar
    Sheffield / Spalding
    Vehicle : Vectra 1.8 SRi
    Engine : Z18XE
    I had something similar on an older Vectra it ended up being the air con pump that had seized. I would hope it wasn't that on such a new car but might be worth a look.
    As tpj2012 writes above I think I have the same problem. Sat in Traffic at the weekend smoke started pouring out of the engine bay, the engine would not turn off when it normally does and the smoking lasted ten minutes, some chaps even came over to my car to suggest it was on fire. It then just stopped and was fine afterwards so I think the clamp near the turbo must be loose and a regen is pouring smoke into the engine bay, I am calling the local dealer to get them to fix it hopefully.
    At the dealers right now, hopefully they will fix it and I can collect it later today.
    Not getting it back today, dealers waiting for a new catalytic convertor and other parts so must be more of a problem than just the suspected loose clamp near the turbo.
    S.Wales, Nr Swansea
    Glad they are sorting it mate, how do you find the bi-turbo? im undecided if i want an Audi Q5 or another Insignia but an Estate
  1. Burning Smell
    By Tam80 in forum Engine & Drivetrain
    Last Post: 13th April 2011, 11:36
  2. burning smell
    By mace in forum Engine & Drivetrain
    Last Post: 7th December 2010, 21:47
  3. burning smell!
    By MARK RC in forum Vectra C / Signum Car Chat
    Last Post: 1st June 2010, 19:13
  4. burning smell
    By tony stoney in forum Vectra C / Signum Car Chat
    Last Post: 9th February 2010, 19:23
  5. Hmm What's that burning smell?
    By Stevel in forum The 'Off Topic' room
    Last Post: 9th March 2009, 21:22
burning smell from vectra
https:www.vectra-c.comforumshowthread.php184359-Smoke-from-bonnet-burning-smell-but-just-once
Vauxhall insignia sports tourer burning smell
vectra estate smoke coming from under the bonnet
burning smell from vauxhall insignia on stopping
insignia 2010 smock coming out of the engine
vauxhall vectra smoke out of bonnet every 8 weeks
vectra c sri 1.8 burning smell
smoke from bonnet and burning smell bur driving fine now
1.8 sri smoke coming from under bonnet
burning oil smell and smoke coming from engine vauxhall insignia
