Results 1 to 10 of 19
Thread: corsa airbag
    wales
    Default corsa airbag
    Hi guys thanks for looking in I have just got my son a corsa 1.2 16v t reg.as he needs a car an hes not driving my signum haha...but his airbag light is on anyone know the cheapest way to clear it.looed at the code readers on ebay but dont want to buy one and it does not work as a lot say the world to you try it..
    P.s i know it not a signum but you guys know loads...
    Regular Member vmb2722's Avatar
    May 2012
    Blackpool/St Mary's Bay
    10 Post(s)
    Trim : Exclusiv
    Engine : 1.9 CDTi 150
    Disconnect the battery for approx 30 mins and then feel about underneath the drivers seat for and loose wires or plugs, I have known this to do the trick on several different cars, it may not work but it don't cost owt!
    wales
    thank you vmb2722 i have tried this had the battery off for two days..no joy
    May 2012
    10 Post(s)
    Trim : Exclusiv
    Take instrument cluster out and remove the bulb!
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Would be worth getting the code cleared and see if it re-appears. I'm sure air bag faults don't clear until you clear them manually.
    ---Sent from my iPhone 5 using Forum Runner
    wirral
    60 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Ask local garage to plug in an check codes
    12 Post(s)
    Quote Originally Posted by vmb2722 View Post
    = MOT failure.
    May 2012
    10 Post(s)
    Trim : Exclusiv
    I was of course not being serious, how long you had the car?
    Regular Member any-mgzt's Avatar
    cheshire
    9 Post(s)
    Trim : basic
    Engine : Z19DT
    Lights on the dash are not currently being regarded as an MOT Failure, still in discussion re the new changes.
    Airbag light will go out if fault recitfied without the need to reset, they do on a Vectra C anyhow, did on mine, before my light was on all the time it was on off on off all the time.
    Not sure about the Corsa, but the Vectra has second plug under seat attached to the front seat frame, small connector about 15mm in diameter and around 40mm long, if the Corsa has that connector try diconnecting and cleaning.
    There was a recall for GM cars in the States to replace this very connector, no such recall here though.
    12 Post(s)
    Quote Originally Posted by any-mgzt View Post
    Lights on the dash are not currently being regarded as an MOT Failure, still in discussion re the new changes..
    Not according to this testers manual - http://www.motuk.co.uk/manual_540.htm
    ABS and ESC warning lights are also checked - http://www.motuk.co.uk/manual_340.htm
  1. AIRBAG light .. is thier a fuse the the Airbag ecu ?
    Last Post: 10th September 2011, 13:21
  2. Airbag replacement - NSF (front passenger airbag)
    By Caveman_nige in forum Bodywork & Interior
    Last Post: 19th February 2011, 21:12
  3. Airbag light reset? - Corsa D
    By mucklestone in forum Electrical & ICE (including SatNav)
    Last Post: 26th June 2009, 12:29
  4. Corsa C Alloy And Corsa D Grille
    By andy.l in forum Parts for sale
    Last Post: 6th May 2007, 12:46
