Results 1 to 3 of 3
Thread: in for a rough ride
    Regular Member Billy Mc's Avatar
    Jun 2012
    Bolton
    Vehicle : Vec C
    Trim : SRI
    Engine : 1.9 cdti 16v
    Mileage : loads
    Default in for a rough ride
    hard to describe but here goes}
    basically had a snapped spring on rear ended up changing full set for apex 35mm drop .
    car is vec 1.9 cdti 16v sri springs are fitted correct way up
    and correct load for axles.
    problem is o/s/f is very stiff almost no bounce
    i did notice on removing springs on front there were 2 different spring sizes.
    i know the factory sri shocks are fine for these springs unsure about standard shocks
    could it be that in the past it has had a standard spring and shock fitted on o/s/f and would this be my problem of the shock bottoming out due to not enough travel.
    or anything else
    cheers guys
    wirral
    61 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Is shock ok?
    Jun 2012
    Bolton
    Vehicle : Vec C
    Trim : SRI
    Mileage : loads
    solved worn front shocks replaced yesterday difference is night and day.
  1. rough ride on low profiles
    By liam51 in forum Vectra C / Signum Troubleshooting
    Last Post: 15th January 2013, 01:48
  2. Really rough on car
    By marc vectra sri in forum Detailing and Car Care Discussion
    Last Post: 12th August 2012, 15:41
  3. Rough as anything! Need your help
    By Big Red in forum Bodywork & Interior
    Last Post: 5th September 2011, 21:21
  4. ride seems rough today
    By kdadidog in forum Styling
    Last Post: 17th March 2010, 19:34
  5. Rough ride - what is wrong with my Veccy
    By mishima in forum Vectra C / Signum Troubleshooting
    Last Post: 1st August 2009, 13:09
