Thread: P0087
    Feb 2011
    Default P0087
    What is this code?? Also where do I start?? Basically every now and then the car will cut out. Very randomly and at no exact time. Turn off and it starts fine. Also sometimes a bit of a rough idle. Any advice/help appreciated
    wirral
    61 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Fuel rail pressure too low
    Can you view live data an see what pressure it thinks is In rail
    next stage would be compare actual voltage to what what ecu thinks
    Feb 2011
    Way over my head lol. I'll take it into garage. Thanks anyway
    wirral
    61 Post(s)
    Trim : Basic
    Engine : 1.9
    Haha ok mate
    what did you use to pull that code?
    Feb 2011
    Another member on here. He had tech 2
    Feb 2011
    Seems to be getting progressively worse. Anything basic I can check?? Can't get into garage till next week as that's when I'm on hols. Thanks in advance
    wirral
    61 Post(s)
    Trim : Basic
    Engine : 1.9
    only basic things would be to check its not leaking.
    as others would require to view love data an then compare it with voltage reading.
    if you have a multimeter you could do some checks
  1. p0087 cde
    By dbgb25 in forum Engine & Drivetrain
    Last Post: 22nd April 2014, 10:14
insignia cut out p0087
Opel P0087
Vauxhall P0087
p0087 vectra cdti
