Thread: Fault code p1110
    Mar 2012
    hitchin
    Vehicle : Vectra c
    Engine : 1.9 cdti 150
    Mileage : 145000
    Default Fault code p1110
    Has anybody had p1110 fault code before, I have the emissions light up on dash, I removed the blanking plate thinking the fault would reset itself, which it didn't. I read the code and it came up with the above.
    So has any one had this before and be able to advise me as to what they did to fix this.
    Thanks in advance
    Dec 2011
    Seaham
    Sure that is the right code?
    Regular Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    12 Post(s)
    Vehicle : Insignia
    Engine : 1.6T SIDI Petrol
    have you got a BOV fitted?
    Mar 2012
    hitchin
    Vehicle : Vectra c
    Mileage : 145000
    Yeah that's the code it's thrown up,
    whats a BOV?
    Jun 2009
    South Coast
    12 Post(s)
    Vehicle : Insignia
    in short an aftermarket dumpvalve type thing... your error relates to charge air bypass valve problem...
    what engine do you have?
    Regular Member david-bell's Avatar
    eastlothian scotland
    Vehicle : vectra vxr
    Trim : vxr
    Engine : 2.8 v6 turbo
    Mileage : 31000
    Just checked my code reader and it says intake manifold air control solenoid 1- circuit malfunction
    Mar 2012
    hitchin
    Vehicle : Vectra c
    Mileage : 145000
    Ok in which case i dont have a bov. I have the 1.9 cdti 150,
    thanks David-bell, I have no clue where to start with that? Again please help with my ignorance!
    Jun 2009
    South Coast
    12 Post(s)
    Vehicle : Insignia
    then you need to be checking your boost solenoid (charge air bypass valve) for issues, or a feed to/from it
    Mar 2012
    hitchin
    Vehicle : Vectra c
    Mileage : 145000
    Excellent, I did clean the little filter as the how2 states on here, filter was clean and made no difference when refitted,maybe I'll swap it with a mates one and see how we get on, cheers fellas I'll keep you posted, thanks for your help so quick,
    May 2020
    Milton Keynes
    Engine : 1.9 cdti
    Quote Originally Posted by rich100 View Post
    Did you manage to solve this ?
    If so HOW ?
    I’ve got you same problem
    Sent from my iPhone using Tapatalk
  1. Fault codes P1109 and P1110, emission light on
    By kristapsl in forum Engine & Drivetrain
    Last Post: 21st January 2013, 01:07
  2. fault code p1110
    By m19hud in forum Engine & Drivetrain
    Last Post: 25th November 2011, 11:22
  3. V6 CDTI P2108 and P1110 fault code help
    By finnyhaggis in forum Engine & Drivetrain
    Last Post: 6th February 2011, 22:59
  4. fault code help
    By madmanc in forum Vectra C / Signum Car Chat
    Last Post: 8th December 2010, 21:46
  5. fault code?
    By chris-green in forum Engine & Drivetrain
    Last Post: 8th December 2010, 19:00
p1110 opel
p1110 vauxhall code
opel p1110
p1110 vauxhall
vauxhall p1110
vauxhall fault code p1110
Opel DTC P1110-4
Opel P1110-4
p1110 opel vectra b
cod eroare opel p1110
vauxhall p1110 fault code
p1110 opel vectra c
Opel Zafira B Engine Z19dt Fault Code P1110p1110 opel vectra b 2.0code deffaux p1110 opel vectra bp1110 vectra v6opel p1110-01gm fault code p1110vectra c error code p1110Opel DTC P1110-04www. GM vauxhaull zafira code P1110vaixhall astra 1.9 code p1110p1110-01 opel astra faultOpel DTC P1110-02error opel p1110-002
