All,
Does anyone know what the AFL dipped bulbs are. It's been suggested to me that it could be either D2r or D2s.
Paul.
All,
Paul.
D2R were in mine when i upgraded to 6000k mate, but you can use D2R D2S or D2C, do you need a spare?
What I have noticed with the newer afl lights on the facelift they are more whiter. I much prefer the pre-facelift blue look from the gsi. Why did you upgrade? Did you go for a more whiter look than standard?
Will be looking in to buying another set to match the pre-facelift colour if I can match the colour temp. I have read where most Vauxhall/ Opel bulbs are 4300K but surely not as they are too blue for that, they look more like 8000K
Cheers,
Paul.
There is a lot to read here guys, but well worth it before you consider changing the K rating of your bulbs.
Clicky, linky.
mate 110% go for 6000k they look much better, they got a nice tint of purply/blue to them, they r like the lights on the new range rovers
I've read it a few times Martin, but i still can't fathom why the older pre-facelift lights have a nice blue glow but my facelift lights are white. Mine light up a nice colour but fade to white after few mins.
I would really like to know the difference in the pre-facelift hid bulbs and the later afl bulbs as in mine. Surely Vauxhall wouldn't have used an 8000k bulb in the GSi's?
Paul.
Yeah, I thought you would have seen it before.
There is a bit in the middle about why BMW's & Audi lights appear blue, I think that probably best explains the likely difference between pre and post facelift, it's probably more to do with the design of the lights themselves and the reflectors/projectors with in them.
Their is a reason most manufacturers stick with 4300-5000K & that is the best temperature range for the best production of light. The higher kelvin you go such as 6000K > the better looking the light (ie:blue/purple colour) but the light produced is simply not as good in light depth & range as the more white/blue of the 4300-5000k range.
My wifes 130i M-sport uses standard 4300k that look almost blue/purple when turned on but settle down to a white/blue after 1 min. The light produced between this colour change cycle is quite obviously in favour of the white/blue stage
