Thread: Dashboard Dies
    Regular Member satbeychap's Avatar
    Devon
    Default Dashboard Dies
    Hi, I have an intermittent problem where my dash dies - all the lights come on for a few seconds and then all the dials and lights go off. Things like the stereo, blower, indicators etc all still work, its just the dash. I either need to turn the ignition off/on OR opening a door also works to get everything back on.
    Any help gratefully received!
    South east
    You could try replacing fuse 17 in the fusebox at the end of the dashboard (passenger side).
    Devon
    thanks - i'll give it a go
    morecambe
    49 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    also clean the abs plug
    Feb 2011
    Oxon
    I had a similar problem where the 'door open' warning light was permanently on, even with doors shut and car locked. The dash died at the same time as the light coming on. Read on here about removing and cleaning fuses 17 and 26 on the passenger side fuse box. I removed them and cleaned them up with carb cleaner and wire wool (they did look dirty) and the problem was solved.
    Might be worth a try....
    Devon
    I was presuming you guys meant the fuse box in the engineer bay next to the battery? I don't have a fuse in #17 or #26?! I cleaned the ABS plug a couple of days ago now and although it didn't appear to be dirty, it hasn't happened since either :-)
    thanks guys
    morecambe
    49 Post(s)
    Vehicle : vectra
    Trim : vxr
    therr ya go mate and no the fuese on the passangers side dash board
    Devon
    Well the problem continues - just started again the other day so I'll check those fuses next.
    I don't think this is related but the engine is super sluggish off turbo and since yesterday the exhaust emissions light has been on so I might get a garage to check everything out.
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Clean the plug/connection on the back of the CIM - very common.
    South West
    Exactly the symptoms i had. Dials die then come back to life... a few weeks fine then happens again. Vx replaced CIM under warranty - but it kept happening. Cleaned the CIM plug and never saw the fault again.
    There is a how to for all the suggestions above.
  1. Engine dies for a second or two
    By Swanni in forum Engine & Drivetrain
    Last Post: 3rd January 2013, 19:55
  2. engine starts then dies!
    By distuio in forum Engine & Drivetrain
    Last Post: 22nd April 2011, 20:55
  3. Vectra 150 dies on start up :(((
    By Gracey in forum Engine & Drivetrain
    Last Post: 26th October 2010, 12:34
  4. Dashboard dies, then comes back on...
    By blinkyzoid in forum Electrical & ICE (including SatNav)
    Last Post: 17th November 2009, 20:48
  5. Entertainer Danny La Rue dies
    By solorider in forum The 'Off Topic' room
    Last Post: 1st June 2009, 18:35
