Thread: Nokia universal phone holder removal
    Regular Member cardiffgareth's Avatar
    Mar 2013
    Vale of Glamorgan
    Vehicle : Vectra C 1.9 CDTi 120bhp 8v
    Trim : Life
    Engine : 1.9 CDTi
    Default Nokia universal phone holder removal
    Right by the heater control for where I want the air to blow is a universal phone holder thats installed in between the trim and buttons. I've tried gently bending it but the plastic trim flexes and I don't want to snap it. This may sound like a daft question but how do I remove the blinking thing! It serves no purpose at all and gets in the way!
    edit - realised this should be in the interior section but I can't see where to delete it ?
    Regular Member ThatAudioBloke's Avatar
    Feb 2013
    Newcastle, UK
    20 Post(s)
    Engine : CDTI 150
    Mileage : 103000
    The heater panel just pops out... If you stick your fingers into the little pocket thing underneath the heater controls and pull forward, it'll unclip. You can then get your fingers under the heater control panel, which will also unclip. The phone holder will more than likely be screwed into the dash covered by the heater control, so just remove and chuck then clip everything else back in. 10 minutes max, if you stop for a cup of tea!
    North West - Assistant RO Woody's Avatar
    May 2012
    North West (Warrington)
    234 Post(s)
    Vehicle : Vectra C 3.2 Elite Estate Auto Facelifted
    Trim : Elite with loads of "Extras"
    Engine : 3.2 Z32SE
    Mileage : 94,000
    You need to remove some fittings which fortunately just "un clip".
    Remove the ashtray and cover with cigarette lighter trim, then remove the cubby hole, next remove the heater control unit.
    All these items are just clipped in, and with a little gentle persuasion will just come off and refit later.
    After that you will probably see where the bracket has been screwed in and will be able to remove it.
    POST CROSSOVER LOL ... What boostpuppy said !
    Mar 2013
    Vale of Glamorgan
    Trim : Life
    Engine : 1.9 CDTi
    Will do this tomorrow! Finally making this car 'my own' !!
    Nov 2012
    london
    Vehicle : Vectra c facelift flame red
    You can slide a 10p coin on the side of the heater control and just pry it it will come off with no scratches or damage...
    Mar 2013
    Vale of Glamorgan
    Trim : Life
    Engine : 1.9 CDTi
    damn blanking plate that's in front of where the phone holder is won't come out, nor will the heater control / cubby hole! Am I not tugging it hard enough?!
    I was tempted to pry the blanking plug with a small screw driver but didn't want to snap anything!
    Feb 2013
    Newcastle, UK
    20 Post(s)
    Engine : CDTI 150
    Mileage : 103000
    They're a pretty tight fit, but they should just pop out with a bit of pressure.
    The blanking plugs should just slide out with a bit of persuasion, but be careful not to mark anything with a screwdriver. At least cover the blade end with some black tape first.
    I use Bojo tools to dismantle dashboards, but for a one off it's a pointless expense.
    May 2012
    234 Post(s)
    Engine : 3.2 Z32SE
    Mileage : 94,000
    Just a thought, and without seeing a photo, difficult to visualise, but I guess whoever fitted the bracket could have screwed through and into the blanking plate which would make removal pretty well impossible ?
    Also, I found it fairly easy to remove the heater controls once the cubby was removed, and before I did that, I also had the ashtray surround removed but can't really comment on whether it was necessary, it just happened that way.
    The cubby removal, try pushing your hand in, and then fingertip pressure tilt it upwards from the rear. Once the clip has released it is plain sailing.
    Mar 2013
    Vale of Glamorgan
    Trim : Life
    Engine : 1.9 CDTi
    Ok! I'll do a take 2 tomorrow !!
    Mar 2013
    Vale of Glamorgan
    Trim : Life
    Engine : 1.9 CDTi
    It's out!!
    Had to take all the bits out that were mentioned above but it's out!
    Looks much better now!
  1. Universal Bush Removal Tool
    By stevie16v in forum Vectra C / Signum Car Chat
    Last Post: 11th November 2012, 14:01
  2. nokia n97 car holder
    By stuart bigboy in forum General items for sale
    Last Post: 3rd May 2010, 20:12
  3. Brodit Holder & Nokia N95 Phone Mount
    By leeds vectra in forum Parts for sale
    Last Post: 24th March 2009, 01:13
  4. Brodit active Holder Nokia N95 Car Kit
    By Kyser143 in forum General items for sale
    Last Post: 11th February 2008, 11:54
  5. Nokia phone holder
    By deanos in forum General items for sale
    Last Post: 6th October 2007, 22:02
how to remove nokia vectra c
