Page 1 of 5 123 ... LastLast
Results 1 to 10 of 45
Thread: Parrot installed - no sound ?
    Regular Member cardiffgareth's Avatar
    Mar 2013
    Vale of Glamorgan
    Vehicle : Vectra C 1.9 CDTi 120bhp 8v
    Trim : Life
    Engine : 1.9 CDTi
    Default Parrot installed - no sound ?
    Hi all, my Vectra came with a parrot installed. It powers up and connects to my iPhone but there is no sound. Making calls, streaming music - nothing. If I activate the voiced menus to rule out an issue with the iphone connection I still have nothing?
    I'm guessing something has come astray but have no idea where to start??
    Also I hear about upgrading the parrot software but I can't see a way of getting it out of the car? How do you update parrot software?!!
    Mar 2013
    Vale of Glamorgan
    Trim : Life
    Engine : 1.9 CDTi
    Doh!! I'm guessing this should of been in the technical section
    Administrator plasma's Avatar
    On the Forum
    548 Post(s)
    Engine : 150
    Mileage : 74000
    do you still have normal radio sound?
    what parrot do u have?
    North West - Assistant RO Woody's Avatar
    May 2012
    North West (Warrington)
    234 Post(s)
    Vehicle : Vectra C 3.2 Elite Estate Auto Facelifted
    Trim : Elite with loads of "Extras"
    Engine : 3.2 Z32SE
    Mileage : 94,000
    I'm not sure if your Parrot will be the same as mine, but updating the software requires that you download the update file from the Parrot website, save it to a USB Memory Stick and connect the stick to the parrot. Then select the file from the Parrot menu system
    Mar 2013
    Vale of Glamorgan
    Trim : Life
    Engine : 1.9 CDTi
    In the parrot menus is says:
    CK3100
    Version 4.16_C
    Display version 1.1
    yes, radio sound is fine, just the parrot not giving me sound. When making a call it doesn't even mute the radio so its like its powering up but not speaking to the head unit?
    Regular Member ThatAudioBloke's Avatar
    Feb 2013
    Newcastle, UK
    20 Post(s)
    Engine : CDTI 150
    Mileage : 103000
    CK3100 will accept an update by Bluetooth, have a look at this link: http://www.parrot.com/uk/support/par...00ck3300ck3500. It will require you to have a laptop with a supported Bluetooth stack (most of them will be using the Microsoft one, if your laptop has Bluetooth)
    It doesn't support music streaming unfortunately, as it is a pure hands-free kit, not a music streaming kit. You'll need an MKi kit rather than a CK kit for that.
    It should have a SOT lead connected to the back of the radio if it's been fitted the easy way, so it might be worth pulling the radio forward and seeing how it's plugged in. Some installers don't bother with a SOT lead, instead preferring to wire it in to it's own live and earth, and sometimes either break into a speaker or provide a third party one. I'd check it with an oldskool Nokia or similar first though, it might just be that your phone is too new to talk to the software on the device.
    Mar 2013
    Vale of Glamorgan
    Trim : Life
    Engine : 1.9 CDTi
    Ah poop, that's blown that idea! The Ck3100 is iPhone 4 compatible though according to that link, shame it won't stream my music
    Feb 2013
    Newcastle, UK
    20 Post(s)
    Engine : CDTI 150
    Mileage : 103000
    It is, for voice calls only though. Maybe yours has an older version software on it, it depends on how long it's been installed for.
    I fitted a CK3100 for a lad I used to work with, and his refused to talk to a new Sony android phone, but it worked fine with his old Nokia brick phone.
    It's also entirely possible that whoever has fitted yours has fitted an external speaker, and for whatever reason (being an utter arse, probably!) has removed it before getting shot of the car.
    Mar 2013
    Vale of Glamorgan
    Trim : Life
    Engine : 1.9 CDTi
    That's a good call, usual places are the footwells so I'll check tomorrow for tell tale signs of disturbance.
    Regular Member haye2412's Avatar
    Aug 2009
    portland
    Hi fitted a parrot on a Vauxhall last week no sound did the up date now alls well with it .
  1. Installed my Parrot
    By wotsthestory in forum Electrical & ICE (including SatNav)
    Last Post: 25th February 2012, 20:07
  2. No sound through parrot
    By BigMart in forum Electrical & ICE (including SatNav)
    Last Post: 13th May 2011, 23:17
  3. gid installed
    By Al 22 dti in forum Vectra C / Signum Car Chat
    Last Post: 21st March 2011, 17:53
  4. How to tell if theres a re-map installed???
    By cammy3000 in forum Vectra C / Signum Car Chat
    Last Post: 31st January 2011, 16:27
  5. New ICE installed
    By Caterman in forum ICE Gallery
    Last Post: 22nd September 2006, 04:14
parrot no sound
parrot ck3100 no sound
parrot not playing sound
parrot no audio
cant hear on parrot in car hands free
parrot car kit no sound
parrot handsfree sound through all speakers
parrot 9200 no usb sound
no sound on parrot mk6100
no audio parrot 3100
how to enable sound in parrot
parrot not coming through speakers
parrot no sound through speakers
volvo s60 2005 parrot 3100 no sound
parrot no sounds
no sound parrot
troubleshooting parrot ck3100 no sound
parrot cant hear music
