Results 1 to 10 of 22
Thread: Lag
    Oct 2012
    Birmingham
    Default Lag
    I've got a 1.9 cdti ls 05 plate the problem is wen I pull off it don't go no where foot to the floor just plods off like I got all day 20 seconds later turbo kicks in and it's off but it happening in every gear unless thrashing it like I stole it any ideas ?
    Regular Member justin32's Avatar
    Aug 2011
    Basingstoke
    5 Post(s)
    Vehicle : Vectra c SRI Facelift
    Trim : SRI
    Engine : 1.9 CDTI 150
    Could be a number of things:
    EGR
    Boost sensor
    Vacume hose
    Air filter
    Fuel filter
    Have you got any warning lights on the dash? does the car smoke at all?
    Oct 2012
    Birmingham
    It ent my car it was sat for bout 3 months and I serviced it coz it was over due and glow plugs had gone so all that got changed the only warning light on is a spanner through a oil can and has been there befor I serviced it I took it for mot and give it a good drive coz it was smoking bad but that now has cleared and all I get is the typical diesel puff every now and then
    Aug 2011
    Basingstoke
    5 Post(s)
    Trim : SRI
    i would get the fault code read,sounds like something is wrong
    Oct 2012
    Birmingham
    Worth cleaning the egr valve to see if it helps ? An does it have to be tech 2 to read code or can I use a normal code reader
    Aug 2011
    Basingstoke
    5 Post(s)
    Trim : SRI
    yeah worth giving it a clean via the how2 on here
    It depends what kind of code reader you have,some handheld ones wont read all fault codes but you never know.
    Oct 2012
    Birmingham
    Had a code reader today come egr malfunction so cleaned it out with it was really bad plugged it bk in no fault codes found but there's still the light oil can and spanner it only comes on when starting and when u turn off and it's still lagging like a ***** also I had another lot keep pooping up a car with a spanner but it would flash up then go off this car is really ****ing me off now any help would be greatful
    Regular Member Eddie Dee's Avatar
    Feb 2007
    BELFAST
    i have the same problem could the swirl flap seals cause this?
    thanks
    edd
    Oct 2012
    Birmingham
    I'm hoping it ent the swirl flaps would the swirl flap not cause problems through the hole range of revs coz this car pulls like a train when it goes
    Feb 2007
    BELFAST
    Try taking off the EGR solenoid and do an operational test with diagnostic equipment, mine was not operating but still didnt bring on the engine management light on I changed the solenoid and fixed my problem.
