Thread: What are the symptoms of a duff glow plug?
    Apr 2011
    Las Vegas
    Default What are the symptoms of a duff glow plug?
    Just as the title says, my cars seems to run on three cylinders on start up, blip the throttle and all is well. Is this a glow plug thing?
    Apr 2011
    Las Vegas
    Oh, and no fault codes present
    wirral
    61 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Poor starting. Rough running on warm up
    possible eml until warmed up
    Apr 2011
    Las Vegas
    Ok thanks for that, sounds like my car. Doesn't through up any faults or lights just sounds ruff as a bag of monkeys until its had a throttle blip. Seems worse in the really cold weather. Car has done 78k so guess its time to swap them out
    Regular Member justin32's Avatar
    Aug 2011
    Basingstoke
    5 Post(s)
    Vehicle : Vectra c SRI Facelift
    Trim : SRI
    Engine : 1.9 CDTI 150
    when i had a glow plug out the spanner light used to come on for about 5 mins and then go out.I had the code read but nothing came up.
    I took out the plugs and did a resistance test with a multimeter and found the dud one and got it replaced.
    wirral
    61 Post(s)
    Trim : Basic
    Engine : 1.9
    Get multimeter on them check for 12v when key turned on.
    then disconnect wire and turn multimeter to ohms.
    Find good earth on engine block an go across am each plug in turn should be under 1 ohm.
    but if you have a failed plug it will be obvious as it will be open circuit or really high ohm reading
    Regular Member mikey_bates's Avatar
    Jul 2012
    Northern Ireland
    Vehicle : vectra c
    Trim : sri
    Engine : 150 cdti
    Mileage : 71200
    sorry to hijack the thread guys but my vec has the car with spanner light comes on on start up replaced all heater plugs so what else is it???
    Jan 2012
    Silverstone village
    Quote Originally Posted by justin32 View Post
    As said the spanned light will be on the dash for 5 mins from cold only, if one or more glow plugs have gone.
    Full Member Z80's Avatar
    Apr 2008
    Noumea
    16 Post(s)
    Vehicle : Opel Vectra GTS
    Trim : Elegance
    Engine : 2.2 DTi 16V
    Mileage : 75 000
    Quote Originally Posted by mikey_bates View Post
    If you've just got the spanner with no other more precise warning light, then you'll have to have your car diagnosed to know more.
    There's a procedure to get some error codes showing on the onboard computer display, maybe someone can post a how-to or link to a thread (did you have a look at the tutorials or technical section stickies already ?)
    Just found the error codes lists yet : http://www.vectra-c.com/forum/showth...ault-code-site
  1. glow plug
    By john norris in forum Engine & Drivetrain
    Last Post: 10th March 2013, 17:57
  2. Glow plug recommendations
    By signum_rob in forum Vectra C / Signum Car Chat
    Last Post: 23rd January 2013, 19:52
  3. Glow plug light
    By jacko52 in forum Electrical & ICE (including SatNav)
    Last Post: 14th January 2010, 21:59
  4. glow plug relay and glow plugs
    By bobk1 in forum Engine & Drivetrain
    Last Post: 3rd September 2009, 17:02
  5. glow plug
    By dominic32 in forum Engine & Drivetrain
    Last Post: 6th July 2009, 21:46
vectra c glow plug symptoms
vectra c symptoms for glow plugs
vectra c symptoms heater plugs gone
