Thread: Wheel stud diameter advice
    Regular Member danlat1415's Avatar
    Lancashire
    Default Wheel stud diameter advice
    Hi,
    Does anyone know the wheel stud diameter of the Vectra?
    I know it's 5 studs, but are all 5 studs the same? or different diameters etc?
    Dan
    Sweden
    Opel/Vx uses 5 x 110
    Regular Member Paddy2bsure's Avatar
    Hertfordshire
    And Saab's are the same too... as long as they're post 1997ish! Tell all... you've found some wheels?
    If they're definitely 5 x 110, the next things you've got to check are the Offset (or ET = Einpress Tiefe... how far "off centre" the bolt face is... think it should be 30 - 40mm from memory depending on the overall wheel width) and the spigot diameter (or Centre Bore diameter) of the wheel, so it sits nice'n'flush on the centre ring of the hub. Not sure of the diameter of this... 63mm at a guess... anyone?
    Lancashire
    Thing is I'm looking for some 17" alloys, but not sure what specs I need to be looking for...??
    Anyone advise me?
    So...
    5 stud
    110 diameter
    Offset?
    etc?
    Hertfordshire
    Quote Originally Posted by danlat1415 View Post
    Anyone advise me?
    So...
    5 stud
    110 diameter
    Offset?
    etc?
    Get yourself some Vectra/Signum 17's in that case... SRI or Elite spring to mind. Can't go wrong then - and they'll look good!
    Yep 5 stud, pcd off 110, though you could fit 108-112 with wobbly bolts. Offset, you are looking for between 35-48,ideally nearer 35 end... Tyres I would go for 225/45x17`s . Though why not go for 18`s as they don`t cost much more but lok a lot nicer ...Also be carefull of the design of the wheel as a few people have had problems with the brake calliper hitting the inside of the wheel, this is purely down to the design of the spokes ...
  1. Tech2 sequence for adjusting wheel/tyre diameter
    By Jerom747 in forum Bodywork & Interior
    Last Post: 15th October 2012, 12:52
  2. Snapped Wheel Stud
    By si_hoss in forum Suspension, Wheels & Brakes
    Last Post: 21st February 2011, 12:17
  3. vectra stud diameter
    By stephen g in forum Vectra C / Signum Car Chat
    Last Post: 29th August 2010, 11:52
  4. Replies: 4
    Last Post: 31st August 2009, 13:43
