Thread: Broken wire on steering rack.
    Nov 2012
    Derby
    Vehicle : Vectra 1.9 CDTI 120
    Trim : Energy
    Engine : 1.9 8v 120 BHP
    Mileage : 170, 000
    Default Broken wire on steering rack.
    My friend recently changed my Alternator but dropped the old one down the back of the engine getting it off.
    It broke off the plug that plugs into the steering rack where the column meets the rack.
    After repairing it with tape he managed to get it back on, however I now have a warning light on the dash (steering wheel ! ).
    Is it a sensor he's broke and if so what's it called ? Where can I get a replacement plug/wire that plugs into it ?
    Many thanks
    wirral
    61 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Your best bet would be from a scrap yard.
    as i think it may only come as part of loom from vxl
    Nov 2012
    Derby
    Trim : Energy
    Mileage : 170, 000
    Thats what I feared. Thanks anyway.
    wirral
    61 Post(s)
    Trim : Basic
    Engine : 1.9
    Have you tried wiggling it to see if can make a better connection?
    Nov 2012
    Derby
    Trim : Energy
    Mileage : 170, 000
    Not tried that yet as I can't get under. Its plugged in tight enough. Gonna have to have it out for a proper repair if I can't find a replacement lead.
    Regular Member any-mgzt's Avatar
    cheshire
    21 Post(s)
    Trim : basic
    Engine : Z19DT
    Remove the connector at the steering pump, I assume it's a facelift with compact EHPS, and remove the sensor with the cable attached then you can clean and inspect on the bench. I damaged mine and did easy repair as only one cable broken managed to solder it back.
  1. Vectra c steering rack dashboard steering wheel
    By Martinlw in forum Vectra C / Signum Car Chat
    Last Post: 22nd February 2013, 23:05
  2. Steering Rack
    By phil0464 in forum Vectra C / Signum Car Chat
    Last Post: 29th January 2013, 15:59
  3. Steering rack AGAIN !
    By FIL 4822 in forum Vectra C / Signum Car Chat
    Last Post: 12th March 2012, 11:42
  4. steering rack
    By pjabrid in forum Vectra C / Signum Car Chat
    Last Post: 5th April 2010, 22:47
  5. steering rack
    By gsi3.2Daveyg in forum Vectra C / Signum Car Chat
    Last Post: 1st April 2010, 20:54
