Results 1 to 10 of 11
Thread: Wet boot!
    Mar 2013
    liverpool
    Vehicle : '04 (54) vectra sri cdti 120
    Trim : sri
    Engine : z19dtl
    Mileage : 178000
    Default Wet boot!
    Hi, my 54 plate vectra sri cdti is letting water in to the spare wheel well. After washing the car i opened the storage compartments at both sides of the boot and found a small amount of water running down the metal panels (the one the fuse box is attatched to and same on other side). Anyone had this before?
    Essex
    28 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    Mileage : 97000
    sometime leaks through the light fitments . others had it come through the roof aerial .
    Mar 2013
    liverpool
    Trim : sri
    Engine : z19dtl
    Mileage : 178000
    Will have a look at that think i'll remove the boot side trims and put it through the car wash in work to see where its getting in, thanks for the info!
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 85000
    Perished aerial seal, very common.
    Regular Member farley2708's Avatar
    antrim n.ireland
    if the aerial base is cracked/perished this could be your best bet also check the trim that runs the roof edging 'gutter trim' i think its called,this lifts up from the rear,there are clips that are rivited to the car when its being made,these have a little 'foam' washer between the rivit & the roof this does perish,toy can buy a pack of 5 from stealers
    hope this helps mate
    Mar 2013
    liverpool
    Trim : sri
    Engine : z19dtl
    Mileage : 178000
    Thanks for the info, will check it out asap and post my findings
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Rear quarters can leak too
    Mar 2013
    liverpool
    Trim : sri
    Engine : z19dtl
    Mileage : 178000
    Quote Originally Posted by tony-1977 View Post
    Do you have any more info on this as this is the area it seems to be leaking, thanks
    Regular Member justin32's Avatar
    Aug 2011
    Basingstoke
    5 Post(s)
    Vehicle : Vectra c SRI Facelift
    Trim : SRI
    Engine : 1.9 CDTI 150
    theres a how2 on removing it so checking would be the same
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Quote Originally Posted by jiffy1986 View Post
    You need to remove the trim inside behind the quarters. Then there's six nuts that hold them in
  1. CV Boot
    By conman in forum Engine & Drivetrain
    Last Post: 11th January 2013, 18:36
  2. Replies: 2
    Last Post: 21st August 2011, 11:38
