Results 1 to 10 of 16
Thread: turbo not holding boost under load
    Mar 2013
    manchester
    Vehicle : vauxhall vectra estate 1.9 cdti 150
    Trim : sport
    Engine : 1.9 cdti 150
    Year : 55
    confused turbo not holding boost under load
    hi im new here and this is my first post ..
    i own a vectra 1.9 cdti 150bhp, its a 55 plate estate sri fitted with a tuning box
    heres my problem -
    i travel to leeds and back each day and basically cruise , when im in 5th or 6th gear and i put my foot down usually on a hill climb whether it be my foot or cruise , i seem to hear a fluttering noise ... and a lack of boost unlike i get in the lower gears ,,
    so then i fitted a conefilter , which highlighted the problem even more !!
    so today i dug myself an old mechanical boost gauge out that reads upto 30psi.. i had a tap in kit from years ago that goes into your rubber induction pipe thats right in front of the throttle body ,, so i took it for a drive and floored it , it goes right past 30 psi upto about 32psi ,..
    now when im in 5th or 6th gear and the fluttering sound starts the boost is bouncing between 26 psi and 32 psi , so i think ive either a turbo problem or actuator problem ,, so i ask you guys what do you think .. any ideas and thoughts would be appreciated
    Jul 2011
    UK
    Year : 06
    I may have a problem the same when I floor it ya can here the turbo spooling but it's goin on and off hard to say it really
    Nov 2012
    Norfolk
    Vehicle : BMW
    Trim : 320D
    Engine : .
    I have that too.
    Regular Member Craig1985's Avatar
    harwich essex
    My friends astra 1.7cdti does this, mainly under loads and low revs 1500/2000 revs.
    Moderator paulhb's Avatar
    Wondering lonely as a cloud
    27 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Have a word with Nutron send him a pm but if your gauge is accurate then there might be an issue unless you have a hybrid and a remap then 30 psi is too much from what Nutron has told me shouldn't be more than about 23 psi as that's all a standard turbo can handle.
    Administrator plasma's Avatar
    On the Forum
    539 Post(s)
    Engine : 150
    Mileage : 74000
    wirral
    61 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Is it standard apart from filter?
    Mar 2013
    manchester
    Trim : sport
    Year : 55
    confused
    hi yes its standard , only a tdi tuning box,, i only used the cone filter so i could hear the problem more as it opens up the system .. as for the boost gauge just used it as a guide to show and explain my problem (it wont be staying) .. my boost shouldnt be fluctuating like it is , i understandy your boost backs off a bit , but it shouldnt be bouncing like it is . im sure it isnt the turbo but maybe the actuator/wastegate , just need a bit more help on this as im not 100% sure .. just to make clear its bouncing up and down on the boost quite spasmodically ...thanks guys
    morecambe
    54 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    your turbos gonna b;ow up soon take that box off for a start even though it onjy adjusts fueling
    Mar 2013
    manchester
    Trim : sport
    Year : 55
    Quote Originally Posted by paulvectrac View Post
    cheers mate . its allready off the problem was there before i put box on , ive only had the car 3 weeks . and noticed this soon after i bought it , like i said only seems to happen when im cruising , and go to overtake say and you give it a liitle gas ,, something telling me actuator isnt holding shut like it should under higher pressure..?
  1. turbo boost.
    Last Post: 26th January 2019, 14:59
  2. no turbo boost
    By emilc in forum Vectra C / Signum Car Chat
    Last Post: 7th April 2010, 17:45
  3. What does your 2.0 Turbo boost to?
    By Mark2.2 in forum Petrol Engine related
    Last Post: 21st February 2010, 14:14
  4. Turbo Boost - anyone?
    By Leviathan in forum Engine & Drivetrain
    Last Post: 23rd March 2009, 15:26
  5. Turbo Boost?
    By Jay Kay 313 in forum Vectra C / Signum Car Chat
    Last Post: 17th December 2007, 18:34
vectra c flutter when under load
