Thread: wiper alignment
    Jan 2008
    ireland
    confused wiper alignment
    hi chaps,
    had to replace wiper motor, but im am having a torrid time re-aligning the arms, they move down an inch slapping the scuttle panelthen doing their proper motion and then the return to normal but slap the scuttle panel again before resting at stop.
    i'll get away with it for a few days but i know i'll cause damage long term, any pictures of where the motor arm under scuttle should be at rest?
    cheers for any help chaps
    Jan 2012
    leicester
    Hi mate got the same prob hope some one can help
    wirral
    61 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Linkage is worn
    Hanging Heaton
    35 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 140k
    Take the arms off and check the bolt holes have splines in them, you need to go counter clockwise a notch...
    If you have moved the arms while the motor has played up you have probably warn these off meaning you need to move and tighten the bolt stupidly to line up, with a lot of trial and error... New arms? Tenner from scrappers and eBay...
    Jan 2008
    ireland
    hi lee, reckon you are right, made a minor movement anti clockwise and that made a massive improvement, its barely kissing the scuttle now. all arms seem to be ok and the linkage is is v tight.
    will maker a minor movement again tom if weather improves and see how i get on.
    Regular Member Greebo's Avatar
    Jan 2012
    In Limbo
    the other option would be that the motor isnt aligned quite right with the arms, you say you replaced the motor so i assume you just got a motor and not the linkage arms as well, I made the mistake when i replaced mine and it was doing exactly what you describe
  1. wheel alignment
    By matt2005 in forum Suspension, Wheels & Brakes
    Last Post: 8th March 2012, 12:32
  2. Wiper Linkage - failed O/S Wiper
    By silver-tongue in forum Engine & Drivetrain
    Last Post: 15th February 2011, 10:29
  3. Trying to Get Alignment Done
    By Jezzy in forum General Chat
    Last Post: 3rd March 2010, 12:49
  4. FLAT FUSION WIPER BLADES KYODO WIPER BLADES Dynamic Flexi Wiper Blades
    By korlinski in forum Vectra C / Signum Car Chat
    Last Post: 25th June 2007, 19:40
