Hi to all
Well i guess i'm a bit of a dinosaur when it comes to technical stuff...
Can somebody expand on the abbreviations of parts that come up in conversations ie. BID TID CIM etc plus any more
Hi to all
CIM = Column Interface Module
TID = Triple Info Display
GID = Graphical Info Display
CID = Colour Info Display
BID = Board Info Display
BCM = Body Control Module
DDM = Drivers Door Module
PDM = Passenger Door Module
ECC = Electronic Climate Control (dual zone aircon)
the list goes on and on.... any more you need ?
REC = Rear Electrical Centre (rear fusebox)
UEC = Underhood Electric Centre (fusebox in the engine bay)
CEL = Check Engine Light (also called MIL)
ECU = Electronic Control Unit
EGR = Exhaust Gas Recirculation
FPR = Fuel Pump regulator
LSD = Limited Slip Differential
MAF = Mass Airflow
MAP = Manifold Absolute Pressure
ODB = OnBoard Diagnostics
ODB II = OnBoard Diagnostics, generation 2
EODB = Enhanced OnBoard Diagnostics
CABV = Charge Air Bypass Valve..
TPMS = Tyre Pressure Monitoring System
TPS = Throttle Position Sensor
and my favourite WOT = Wide open Throttle (pedal to metal, foot to floor)
MIL = Malfunction Indicator Light (Nige used the acronym!)
Will admit, I always thought FPR was Fuel Pressure Regulator myself?
Ah, I was wondering what all the '*ID's were lol, so that's good! Still don't know what's different between a bid and gid though? Surely both are graphic and show board info? :s
bid is board info disply gid is graphic info display
Yeah I saw that, but both show on board info don't they? And both are GUIs?
TID:
BID
GID
CID
Oh, I see, cheers!![]()
